Results 1 to 12 of 12
Thread: Request for IEC-62271-1
    Thumbs up Request for IEC-62271-1
    Please upload if any one have IEC 62271-1
    IEC 62271-1 2007 High-voltage switchgear and controlgear – Part 1 Common specifications.pdf 2.072 MB
    Dear Nabilia,
    Bundle of thanks
    Re: Request for IEC-62271-1
    Dear All,
    Any body have IEC 60060-1? Please upload.
    Thanks & Best Regards
    Kavita
    IEC 60060-1 Ed. 3.0 2010
    Anyone, who can re upload IEC 62271-1 2007 High-voltage switchgear and controlgear – Part 1 Common specifications.pdf ?
    Nabilia, can you re upload IEC 62271-1 2007 High-voltage switchgear and controlgear – Part 1 Common specifications.pdf ?
    Try
    Thank you.
  13. Re: Request for IEC-62271-1
    please upload IEC 62271-1 again
    the links are not working
  14. Re: Request for IEC-62271-1
    Oh I came here for that standard ... Links are down.
  16. #12
    IEC 62271 High voltage switchgear & controlgear.rar 47.812 MB
    consist of :
    AS 62271.202-2008 High-voltagelow-voltage prefabricated substation
    BS EN 62271-1-2008 Common specifications
    BS EN 62271-100-2009 Alternating current circuit-breakers
    BS EN 62271-104-2009 Alternating current switches for rated voltages of 52 kv and above
    BS EN 62271-105-2003 Alternating current switch-fuse combinations
    BS EN 62271-109-2009 Alternating-current series capacitor by-pass switches
    BS EN 62271-110-2009 Inductive load switching
    BS EN 62271-202-2007 High voltage low voltage prefabricated substation
    BS EN 62271-205-2008 Compact switchgear
    IEC 62271-1-2007 Common specifications
    IEC 62271-2-2003 Seismic qualification for rated voltage of 72.5 KV
    IEC 62271-100 High-voltage switchgear and controlgear - High-voltage alternating-current circuit-2003
    IEC 62271-102 High-voltage switchgear and controlgear - High-voltage alternating-current Disconne 2001
    IEC 62271-105 High-voltage switchgear and controlgear - Alternating-current Switch Fuse Combinati 2002
    IEC 62271-200 High-voltage switchgear and controlgear - AC metal-enclosed switchgear and controlg2003
    IEC 62271-202 (2006) High-voltagelow-voltage prefabricated substation
    IEC 62271-203 High-voltage switchgear and controlgear - Gas-insulated metal-enclosed swithgear 2003
    IEC 62271-209-2007 Cable Connections for Gas-insulated Metal-enclosed Switchgear for rated Voltages above 52kV-Fluid-filled and extruded Insulation Cable
    IEC 62271-308 High-voltage switchgear and controlgear - Guide to Asymetrical shoet circuit breaki 2002
    IEC TR 62271-310 High-voltage switchgear and controlgear - Electrical endurance testing for circu 2004
  1. API 571 request
    By barbara in forum Petroleum Refining
    Last Post: 12-29-2017, 10:30 AM
  2. IEC 62271-1 Required
    By moon619 in forum Electrical & Power Engineering
    Last Post: 02-17-2015, 07:10 AM
  3. Iec 62271-202. /iec 61330
    By ehtisham in forum Electrical & Power Engineering
    Last Post: 11-26-2011, 09:28 AM
  4. [Request] NFPA T3.5.1:2002 (R2010) request
    By gospel85 in forum Electrical & Power Engineering
    Last Post: 03-18-2011, 03:52 AM
  5. Iec 62271-200
    By imran_chauhan in forum Electrical & Power Engineering
    Last Post: 11-04-2010, 08:04 AM
