1st of all
Guys..
I will not answer any questions anymore ,, if u ask with private messages.
I am getting lots of questions and most are the same..
If u have a question please post in the thread so I dont need to answer the same question everytime to a differnet member please ask here and I will answer it as soon as I can
Here is wht I did,, so simple.. tried it on 2 computers both with win 7 64bit Ultimate ( tested with all AspenOne V 7.2 products and all works)
- disable UAC (User Account Control)[link Point to another website Only the registered members can access]
- Run lic gen and wait for it to finish. (will take a while), while waiting check pdf file (link at the bottom)
- Install MSQL server backword compatibility
h tt p://h otfile.com/dl/116198115/4b7d227/SQLEXPR_RUS.rar.html
- Load Aspenone V7.2 DVD and autorun will start
- Once the autorun loads up, choose products and a new window will pop up, (a valid license is required) press ok
- New window will appear, press install
- Select standalone for license configuration type.
- Click Next
- Select Add license
- Go to C:/ Drive (windows 7 installation drive) select AspenOne from C:/ drive root and select LSERVC_********.Lic
- Then open.
- You will see the license being generated for one or two min. (710 license found) after that click next
- No need to add server, just click next
- Keep clicking next if required, then go and install AspenOne products (hysys and everything else u need)
- skip username password and doamin
- restart after installing
Notes
- if u were asked during the installation for standalone or server, choose standalone.
- if u had an error during installaion (MSQL not running), choose yes to enable it.
PDF file for pictures
w w w.h otfile.com/dl/115765750/964fb2a/Aspen_one_installation.pdf.html
Saif
