Results 1 to 10 of 10
Thread: Static bottom hole pressure
    Please can i calculate static BHP IF I HAVE Pfw bottom hole flowing pressure
    please help meeeeeeeeeeeee
    Thanks in advance
    Nov 2008
    Australia
    To take FBHP to Pr, you need rate, kh/Skin, reservoir size and drawdown/buildup pressure behaviour etc information - essentially this is the process of welltesting
    Thank you for your reply I know your mean but I mean if I have Pwf only how can i get SBHP
    Nov 2008
    Australia
    I dont think you do know what I mean, because if you did you would not be asking the same question again
    If all you have is Pwf then there is no way you can come up with anything close to a unique solution of Pr
    IF you have rate history, know the initial reservoir pressure, make some assumptions on reservoir size/geometry and kh, then you can do some simple simulations to try to come up with a likely range of reservoir pressure. Similarly, depending upon whether you thought you were in transient/steady-state/pss, you could use one of a few different analytical equations that along with a rate you could (gu)estimate the reservoir pressure.
    If ALL you have is Pwf, then you are sol
    THANK YOU SO MUCH FOR QUICK REPLY.IF I HAVE Kh and history rate and reservoir size please what is the formula that will use to calculate Static BHP
    Nov 2008
    Australia
    For steady state - Darcy's equation
    For transient - try Earlougher's equation. But if you are still in transient flow, you probably have not have much depletion yet and so could probably just assume Pi
    Thank you so much for your cooperation.please have you any materials for Eclipse program courses .I got good materials form this forum.
    again thank you
    Dec 2007
    Novi Sad, Serbia
    The easiest way to estimate BHSP from Pwf is to draw Pwf vs.Q ...and extraplotae the line to Q=0 Sm3/d
    best regards
    Thank you so much for your reply and explain
  1. Choke size an bottom hole pressure
    By ibtisam01 in forum Oil And Gas Production
    Last Post: 12-06-2016, 10:30 AM
  2. Article: Choke size an bottom hole pressure
    By ibtisam01 in forum Home Articles
    Last Post: 05-22-2014, 04:22 PM
  3. PowerPoint presentation for BU analysis, Bottom Hole Pressure interpretation....
    By ahmedj9579 in forum Engineering Spreadsheets & Presentations
    Last Post: 03-02-2012, 12:12 PM
  4. Replies: 10
    Last Post: 01-06-2011, 11:07 AM
  5. Replies: 1
    Last Post: 01-02-2011, 03:59 PM
