Hi all,
Please, help me to find the sarurate extension file saturate.dll for HYSYS 7.2.
Thank you so much in advance.
Best regards,
Hi all,
Best regards,
saturate.dll
Thanksso much
This file is currently set to private. ...can you please unprivate it agai
n...
Thanks!
done.
Great! Many Thanks!
Hai,
Sorry to interrupt, do you have the gas properties extesion.dll for hysys. I need that extension to generate the water dew point for my final year project.
Thank you in advance for the help
Cheers![]()
Calculates Wobbe Index Higher and Lower Heating Values, Dewpoints, Water Content, Cp, Cv for a selected stream.
Thanks![]()
Dear all,
I have already download it, greatt..., but now i have some problem how to install it. I have copy and paste the Saturate Folder to Folder extention (Program files(x86)>> Aspentech >>Aspen HYSYS v7.2 >> extentions) but its doesn't work. Does anyone know the procedure please?
Thank u
Register & Access SATURATE Extension
Once the SATURATE extension is downloaded, it shall be registered in HYSYS. Unzip the saturate.edf and saturate.dll files to a convenient directory on your hard disk. Go to Tools … Preferences, then choose the Extensions tab, click the Register an Extension button, then navigate to the location of the saturate.dll file. Local Administrator privileges are required in order to register an extension. The Saturate Stream Unit extension should then appear under the Extensions category of the Add Operation window. (Accessible via Flowsheet … Add Operation, or by pressing F12.)
