Results 1 to 10 of 10
Thread: BS EN 837 - Pressure Gauges - Standard Range
  1. BS EN 837 - Pressure Gauges - Standard Range
    Hi..any body having this standard "BS EN 837 - Pressure Gauges - Standard Range" ........Plz sahre or send me: instsuresh@gmail.com
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    Please find here with part 1 to 3 of BS EN 837 1998
    Pressure ranges
    The bar is the preferred unit of pressure.
    Pressure ranges in bar:
    0 to 0,6 0 to 6 0 to 60 0 to 600
    0 to 1 0 to 10 0 to 100 0 to 1000
    0 to 1,6 0 to 16 0 to 160 0 to 1600
    0 to 2,5 0 to 25 0 to 250
    0 to 4 0 to 40 0 to 400
    Vacuum ranges in bar:
    Vacuum gauges have anticlockwise pointer travel with
    increasing vacuum.
    20,6 to 0 21 to 0
    Combined pressure and vacuum ranges in bar:
    21 to +0,6 21 to +3 21 to +9 21 to +24
    21 to +1,5 21 to +5 21 to +15
    The SI units kilopascal (kPa) and megapascal (MPa)
    should follow the bar series from 0 to 60 kPa up
    to 1000 kPa, then change to 0 MPa to 1,6 MPa up to a
    maximum of 160 MPa.
  6. Dear amshah,
    Some pages are not available
    Please check and kindly upload again
    Thank you so much
  7. The given link has not been working kindly upload it again.
    Thanks & Regards,
    Vivek
    File Expired! Re-put the Link please Amshah!
  10. Re: BS EN 837 - Pressure Gauges - Standard Range
    Thanks & Regards,
    Vivek[/QUOTE]
    AKDESARKAR
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    This what i have
    Thank you really useful
    Nov 2010
    Beijing, china
    thx a lot
  1. Klinkenberg and MICP pressure range question
    By vinomarky in forum Reservoir
    Last Post: 01-15-2014, 12:25 AM
  2. looking for ASME B40.100-2005 Pressure gauges and gauge attachment
    By parky14 in forum Instrumentation & Control
    Last Post: 06-13-2013, 12:51 PM
  3. Pressure Vessel Standard Required
    By Dipesh Shah in forum Engineering Certificates
    Last Post: 05-14-2013, 02:32 PM
  4. PED Pressure Equipment Directives Standard is required
    By siamak in forum Mechanical Engineering
    Last Post: 02-05-2013, 04:10 PM
  5. Criteria for choosing a Range of Pressure Gauge
    By mtt2005 in forum Instrumentation & Control
    Last Post: 04-12-2011, 05:15 PM
