Thread: steel pipe line nomencleature
  1. Exclamation steel pipe line nomencleature
    I am searching alot about the codes regulate the coding of process gas pipe lines according to rating....where I can find such codes denotes the rating with material...
    e.g
    AH3, B3, DL3, DW3....etc
  3. oh i found it ...but does it work any where else out of Enppi?
    CLASS CODE- RATING- PIPING MATERIAL
    A3- 150#- CARBON STEEL
    AA3- 150#- CARBON STEEL
    AH3- 150#- KILLED CARBON STEEL
    AV3- 150#- 304 STAINLESS STEEL
    B3- 300#- C.S
    BH3- 300#- KILLED C.S
    BV3- 300#- 304 STAINLESS STEEL
    D3- 600#- C.S
    DH3- 600#- KILLED C.S
    DV3- 600#- 304 ST.ST.....
    no LD3 mentioned, and AW3.....how could such codes been got?
  1. AWS D10.8-RP for welding of Cr-Mo steel pipe and tube
    By cpchonburi in forum Mechanical Engineering
    Last Post: 12-15-2017, 12:11 PM
  2. Distribution of Pipe Load on the Steel Pipe Rack
    By Saleih.com in forum Civil & Structural Engineering
    Last Post: 12-14-2013, 06:56 PM
  3. Smys a37 pipe steel
    By aaguiar in forum Pipeline And Fluid Flow
    Last Post: 06-13-2013, 09:13 PM
