I found this on the web
YOKOGAWA Centum cs3000 keycode for software installation with simulation
Yokogawa CENTUM CS 3000 R3.02.30
Instructions
You can create and simulate only one (1) FCS and and more than one HIS in a single PC..
what You need..:
1. CS3000 Software Medium R3.x.xx (I think old version it's not function)
2. Cd Key in Flopy disk
How to install :
1. Insert Softwrae Medium cdrom.
2. Insert Cd key to drive A or flopy driver
3. Run setup at Software medium cdrom.
4. Follow the instruction, If ask ID.. just open cd key file"Revision.KCD" with notepad and you can find where the ID.. Very Happy
5. At installation proccess, program will ask for "next Cd key" or "next Software medium". just select "No" option.
6. After finish do not select operator keyboard and com port just skip it.
7. Installation finish, and restart.
How to use Simulation:
1.After PC restrat, you can see small icon intray ( you will find it)
2.Select "Start--> Program-->Yokogawa Centum-->System View"
3.Program opened and dialog box appear that you do not have Project .
4.Select yes to create project and follow the instruction..( read manual for creation project, FCS and HIS)
5. After project has created, you can beginning run simulation..
). Is it possible to make it more than one FCS. I installed and I want to use it in a project which includes more than one FCS. Thank you
