Thread: what is a gasket?
    what is a gasket?
    what is a gasket?
    what is a gasket?
    According to Wikipedia, a gasket is a mechanical seal that fills the space between two objects, generally to prevent leakage between the two objects while under compression.
    Other definitions/descriptions of gasket:
    "A flexible material used to seal components together; either air-tight or water-tight" (PartSelect.com).
    "Any of a wide variety of seals or packings used between matched machine parts or around pipe joints to prevent the escape of a gas or fluid" (Staffgasket.com).
    Gaskets are commonly produced by cutting from sheet materials, such as gasket paper, rubber, silicone, metal, felt, fiberglass, or a plastic polymer.
    Gaskets save money by allowing less precise mating surfaces on machine parts which can use a gasket to fill irregularities. Gaskets are commonly produced by cutting from sheet materials, such as gasket paper, rubber, silicone, metal, cork, felt, fiberglass, or a plastic polymer (such as polychlorotrifluoroethylene). Gaskets for specific applications may contain asbestos. It is usually desirable that the gasket be made from a material that is to some degree compressible such that it tightly fills the space it is designed for, including any slight irregularities.
    Gasket is very important in a process plant. It maintains the energy, temperature and pressure in a process system. Selecting a suitable gasket is a must because it does cost money. It is also directly related to the process temperature, pressure, type of medium (fluid or gas) and the chemical properties of the medium.
    Another new knowledge that I learned is about spiral wound gasket that can withstand pressure up to 70-80 bar. It is a very interesting and carefully manufactured gasket made of stainless steel. However, I shall elaborate more about this in another post because it is deserve its own post!
    OK, let me just explain about the simple/normal gasket. With reference to the left illustration, the gasket is sandwiched between flanges. The property of the gasket and correct compression/tightness allows the process system to maintains it pressure and would not allow oil or gas to leak.
    The above illustration shows how a gasket is positioned and locked between those 4 bolts.
    Another illustration shows how a gasket is positioned and locked between those 8 bolts.
    We install/fix the correct type of gasket before connecting the pipeline with flanges.
    The above photo is a very interesting one. It shows the condition of gasket after being used for some time. It is difficult to remove the gasket by bare hands because the gasket sticks very well. We need to use suitable tools to peel and remove the gasket from the flanges. Usually, flanges like this is opened during shutdown to clean/clear pipelines or vessels. After inspection, a new fresh gasket will be used. Never use a gasket twice.
    Without a gasket, a 12" butterfly valve like this will leak and spill oil or water and spray gas or steam (depending on your application).
    Gasket is not only used between flanges. It is widely used everywhere in a process plant and in our kitchen (the refrigerator). In a plant, gasket can be found in the heat exchanger, valves, vessel man holes etc. The gasket needs to be properly maintained to ensure no upsets in the plant.ets in the plant.
    Quality education is the best investment for your future,Knowledge is power
    Give me a spot to stand in and i well shake the whole world
    Thx again freeman.
  1. gasket
    By smileya_vp in forum Mechanical Engineering
    Last Post: 07-03-2014, 01:25 PM
  2. Gasket Characteristics
    By Esam in forum Pipeline And Fluid Flow
    Last Post: 07-26-2011, 09:30 PM
  3. PTFE gasket
    By Ramalingam in forum Mechanical Engineering
    Last Post: 11-22-2010, 08:41 AM
  4. Diesel gasket
    By ackeiyword in forum General Engineering
    Last Post: 11-13-2010, 12:12 PM
  5. PTFE Gasket 'm' and 'y' value
    By mbc.engg in forum Mechanical Engineering
    Last Post: 06-29-2010, 04:17 AM
