Results 1 to 5 of 5
Thread: Flow Of Compressible Gas In Pipeline
    Flow Of Compressible Gas In A Horizontal Pipeline
    The four commonly-used equations for long-distance gas pipeline are:
    - Weymouth Equation
    - Panhandle A
    - Panhandle B
    - AGA (American Gas Association)
    Another equation was recently derived by Ohirhian via the manipulation of three basic equations : Weymouth, Colebrook and Reynold's number.
    Each of the above five gasflow equations is based on some assumed expression for Friction factor ƒ , a dimensionless correlating function. ƒm is the friction factor (also called the Moody friction factor) that is commonly tabulated in the Moody Charts. Quite often the Fanning Friction factor ƒf is used: ƒf = ƒm/4.
    The equations for each method is given below:
    - Weymouth Equation:
    - Panhandle A:
    [link Point to another website Only the registered members can access] - Panhandle B:
    - AGA (fully turbulent):
    - Ohirhian:
    Where:
    qsc = gas rate at standard condition, scf/d
    P1 = inlet pressure, psia
    P2 = outlet pressure, psia
    Psc = pressure at standard condition, psia
    Tsc = temperature at standard condition, &degR
    Tm = mean temperature of line, &degR
    Tg = ground temperature, &degR
    μ = mean gas viscosity, cp
    γ = mean gas relative density (air = 1)
    Zm= mean gas compressibility factor
    d = inside diameter of pipe, inches
    L = pipe length, miles
    E = pipeline efficiency
    ƒm = Moody friction factor
    ƒf = Fanning friction factor
    Ft = transmission factor (√[1/ƒf ])
    ε = absolute roughness of pipe, inches
    The mean values of the gas properties (Z & μ) are determined at the average pressure and temperature, derived as follows:
    BIBLIOGRAPHY
    • Maddox R.N. & Lilly L.L.; Gas Conditioning & Processing, Volumes 2 & 3; Campbell Petroleum Series, Norman, Oklahoma, 1990.
    • Katz D.L. & Lee R.L.; Natural Gas Engineering - Production & Storage; McGraw-Hill Publ. Co., New York, 1990, chap. 6.
    • Ohirhian P.U.; Direct calculation of the gas volumetric flow rate in horizontal and inclined pipes; Paper SPE-37394, Soc. of Petroleum Eng., Richardson, Texas, 2002.
    Quality education is the best investment for your future,Knowledge is power
    Give me a spot to stand in and i well shake the whole world
    Flow Of Compressible Gas In An Inclined Pipeline
    For a slightly inclined pipeline, flow rate predictions are obtained by the modification of the horizontal gas pipleline flow equations. The elevation change (positive uphill, negative downhill) is compensated for by adding the static head of gas column to the pressure loss calculation.
    - Weymouth Equation
    - Panhandle A
    - Panhandle B
    The equations for each method is given below with the eS and Le terms accounting for elevation change :
    - Panhandle A:
    - Panhandle B:
    -AGA (fully turbulent):
    Ohirhian:
    Where:
    Le = effective pipe length, miles
    ΔH = Change in elevation between inlet & outlet (ft)
    [link Point to another website Only the registered members can access] BIBLIOGRAPHY
    • Tian S. & Adewusi M.A.; Development of analytical design equation for gas pipelines; Paper SPE-24861, Soc. of Petroleum Eng., Richardson, Texas, 1992.
    can u translate it in to international units?
    and i want to know how to convert BWRS EOS's unit ,and use it in to gas pipeline simulation?
  6. Pipe Line diameter
    How can we find the diameter of compressed natural gas pipe line if flow rate and pressure is given.
    If anyone has ebook related to this, please inform soon.
    Muhammad Irfan
    i have the Chinese version, do u want to have a look?
  1. Gas flow rate inside Pipeline
    By eng.7ossien in forum Engineering Spreadsheets & Presentations
    Last Post: 03-11-2015, 01:27 AM
  2. Pipeline or Flow Assurance Engineering
    By sean77 in forum Jobs
    Last Post: 12-05-2013, 09:54 AM
  3. Computational Rheology for Pipeline and Annular Flow
    By Azad in forum Pipeline And Fluid Flow
    Last Post: 09-03-2013, 02:13 PM
  4. Compressible Fluid Flow
    By Mohamed in forum Pipeline And Fluid Flow
    Last Post: 01-16-2009, 02:18 AM
