Thread: Flow Of Liquid & Compressed Gases Through Circular Pipe
    A common engineering problem to be able to determine the losses (analysis), or velocity (prediction) or the conduit size (design) of a piping system. Flow in a pipe is characterized by 7 parameters: Fluid viscosity & specific gravity, Pipe internal diameter, roughness & length, Flow rate/velocity & head loss/pressure drop. Based on which of the parameters are known, four types of computational problems are identified: namely the Calculation of i) Pressure drop, ii) Flow rate, iii) the Pipe internal diameter and iv) Pipe length. This task is accomplished by appropriate rearrangement, substitution and iterative solution of the following Equations:
    Reynolds Number Re=VD/ν
    where
    Re = Reynolds Number
    Q = average flow rate
    V = average flow velocity
    γ = fluid specific gravity
    ν = kinetic viscosity, centistokes
    D = pipe inside diameter
    L = pipe length
    ε = absolute internal pipe roughness
    ƒ = friction factor
    ΔZ = change in elevation
    h = pressure head
    hf = head loss due to pipe friction
    Lm = head losses due to fittings, valves, etc(length equivalent)
    P = pressure
    g = gravitation acceleration
    Quality education is the best investment for your future,Knowledge is power
    Give me a spot to stand in and i well shake the whole world
    can u give me the book?
    my e-mail
    yuannweimin_123@yahoo.com.cn
    thank u very much
  5. Can any one please tell how to calculate pipe diameter for natural gas pipe line.
    Also is there any software in this web site use to calculate pipe dia for different systems.
    mirfan389@yahoo.com
    Muhammad Irfan
  1. Flow rate,velocities and losses in non-circular pipes..
    By rizzyk in forum Pipeline And Fluid Flow
    Last Post: 11-11-2013, 04:11 AM
  2. CGA Compressed Gases and Design
    By shabba in forum Oil And Gas Process
    Last Post: 10-07-2013, 11:38 AM
  3. Replies: 1
    Last Post: 07-15-2010, 05:47 PM
