Thread: Reynolds number and friction factors
    Flow Through Circular Pipe
    The Reynolds Number (Re), is a dimensionless parameter for characterizing fluid flow. It is the criterion used to determine whether flow is Laminar, Critical (transitional) or Turbulent. Usually for laminar flow Re <> 4000.
    The Darcy friction factor is a Reynold number-dependent factor used in the computation of the pressure loss due to pipe roughness. Friction factor is commonly computed via the implicit Colebrook-White equation and more recently by explicit equations by Churchill, and by Swamee & Jain. Colebrook-White and the Swamee-Jain equations were designed for the turbulent flow regime, but will be used here also for the critical regime. Churchill's equation spans the entire range from laminar to turbulent. The Fanning factor and the Transmission factor are derivatives of the Darcy friction factor. The relevant equations are given below:
    Reynolds Number Re=VD/ν
    Fanning friction factor ƒf=ƒd/4
    Transmission factor F =2/√ƒd
    where
    Re = Reynolds Number
    V = average flow velocity
    ν = kinetic viscosity, centistokes
    D = pipe inside diameter
    ε = absolute internal pipe roughness
    ƒ = friction factor
    ƒd = Darcy friction factor
    ƒf = Fanning friction factor
    F = Transmission factor
    Quality education is the best investment for your future,Knowledge is power
    Give me a spot to stand in and i well shake the whole world
  3. I am looking for the "Handbook of Hydraulic Resistance". If you have a copy, Please upload it. Thank you
  1. Manual Valves K factors
    By khalid655 in forum Engineering Spreadsheets & Presentations
    Last Post: 04-04-2016, 07:50 AM
  2. Friction factors for torque and drag analysis
    By scipiond in forum Drilling And Workover
    Last Post: 08-06-2014, 04:25 PM
  3. friction factor
    By nguyene2 in forum Drilling And Workover
    Last Post: 06-19-2012, 03:51 AM
  4. Reynolds Number
    By Esam in forum Pipeline And Fluid Flow
    Last Post: 07-26-2011, 05:40 PM
  5. Replies: 0
    Last Post: 01-22-2009, 10:12 PM
