Results 1 to 10 of 10
Thread: DIN Standarts
    DIN Standarts
    I need DIN standarts for piping and fittings. If any one has it, please share.
    M. LT
    Biete schoen das sind alles was ich habe
    DIN 86090-2008 Fitting for Buttwelding for copper-nickel alloy pipeline - Elbow.pdf 1.04 MB
    DIN 11852-2007 fittings for the food and chemical industries -fittings of Stainless steel - Tees, be ... 763.37 KB
    DIN 2505_V-1986 Calculation of flange joint.PDF 627.51 KB
    DIN EN 1092-1 2008 Flanges and their joints – Circular flanges for pipes, valves, fittings and ... 1.48 MB
    DIN 2695-2002 Diaphragm-weld packings and weld ring seals for flange connections.pdf 0.112 MB
    Achmad
    Thank you for your support. I also need DIN norms for piping. If any one has it, please share.
    M. LT
    Vielen Danke Achmad
    Nochmals :
    DIN.rar 5.84 MB
    Einzelhaiten sind :
    DIN_EN_10253 Butt Welding pipe fitting:
    DIN_EN_10253-1_Wrought carbon steel
    DIN_EN_10253-2 Unlegierter u legierter Sthal mit besonderen Pruefanfoerderungen
    DIN_EN_10253-3 Duplex Stainless Steel without inspection
    DIN_EN_10253-4 Duplex Stainless Steel with inspection
    DIN 16963 - Pipe Joints & Elements for HDPE :
    DIN 16963-1-1980 Pipe bend for segmental constuction f butt-welding
    DIN 16963-2-1983 Tees and branches
    DIN 16963-3-1980 Pipe bend for Butt welding dimensions
    DIN 16963-5-1999 General quality and testing requirement
    DIN 16963-6-1989 Injection pipe fitting f butt welding – dimension
    DIN 16963-8-1980 Injection moulded elbow f socket welding – dimension
    DIN 16963-10-1980 Injection moulded socket & caps f socket welding – dimension
    DIN 16963-13-1980 Turn & reducing socket f butt welding – dimension
    DIN 2696-1999 Lenticular ring joint gasket for flanged joint
    DIN 2982-1978 Threaded steel pipe fitting, barrel nipple
    DIN EN 1514-1-1997 Masse f. Dichtungen f Flansche mit PN Bezeichnung
    DIN 86064-1976 Connecting socket w. pipe flange nom pressure 10
    Thank you very much sir.
    Thank You Very Much
  11. Re: DIN Standarts
    Dear Achmad,
    Would you please advise how to download the link above, especially for DIN 2505?
    Why it is goes to something else.
    Thanks in advance.
    TK
    Re: DIN Standarts
    Anybody has EN13920 please share?
    Re: DIN Standarts
    gud day sir , anybody have DIN 2614?
  1. ASME PVHO standarts
    By coverall in forum Mechanical Engineering
    Last Post: 02-27-2014, 01:03 PM
  2. Hydraulic Symbology, Standarts and Books
    By CCCP in forum Mechanical Engineering
    Last Post: 04-28-2013, 03:19 PM
  3. DIN Standarts
    By Levent in forum Pipeline And Fluid Flow
    Last Post: 02-12-2011, 07:14 PM
