Results 1 to 7 of 7
Thread: Yaws' Handbook of Thermodynamic and Physical Properties of Chemical Compounds
    Description:
    This is an enormous collection of physical, thermodynamic, and transport property correlations for 5000 organic chemical compounds covering C1 to C70 organics. The data is provided in a tabular format with links to an interactive Equation Plotter Applet that graphically represents the temperature correlation relationships for 15 key properties. The data is both experimentally determined and estimated based on methods developed by the author and other noted experts. Detailed references are provided for further research.
    Accurate information describes how chemicals behave at different temperatures in an easy-access format. The Equation Plotter Applet can save countless hours of complicated calculations. Update Description: Yaws' Handbook of Thermodynamic and Physical Properties of Chemical Compound has been updated to include 16 new interactive tables (57,000 records) on thermodynamic, physical, and transport properties of organic chemical compounds. 9 of the tables have Equation Plotter interactivity and almost all have synonyms.
    http://image.gostshare.com/files/ukl1rplu9bdo8koiwmnz.gif
  3. thanks
  5. Thank you
  6. thanq lot brother
  7. thanks very much
    but how can i use it?
    it doesnt have an index to find something and when i open one file with an explorer it doesnt show the contents completely
    and how to use the equation to find the chemical properties in different temperature ?
    thanks again.
  9. Re: Yaws' Handbook of Thermodynamic and Physical Properties of Chemical Compounds
    the link is not working
    could you please upload it again
    regards
    I need this handbook
    can you re-upload
  1. Yaws' Handbook of Thermodynamic
    By nwingwon in forum Pipeline And Fluid Flow
    Last Post: 05-26-2014, 12:21 PM
  2. Replies: 13
    Last Post: 11-09-2010, 11:24 AM
  3. Need: Handbook of Physical Properties of Liquids and Gases:
    By ongkc1 in forum Safety And Environment
    Last Post: 11-02-2010, 06:21 AM
  4. Handbook of Hazardous Chemical Properties
    By nour in forum Safety And Environment
    Last Post: 09-30-2009, 05:11 PM
