hi
Workover Office XP/2003
Features: braden head, cementing, completion software, Completions, packer software, perforating, perforations, spreadsheet software, wellbore graphics, workover software
Workover Office Professional edition has an extensive library of over 1000 hi-resolution Workover, wire line, coiled tubing, gravel packing, flow control and completion tools which can be auto selected and dropped into your final well sketch
Print, Export to your Well File or Email, any of the following; 17 common completions,
Well Head, Schematic, Packer calculations, Balanced Cement Plugs, Tubing Movement, Tie Backs, Liners, GLM Placement, Tubing Tally, Tubing Tally Sheets, Final Completion Well Bore Schematic, Frac Manifold graphic
This is the first and most comprehensive Workover office program in the oil -----. All you need to do is to identify your general well sketch and click on the button below the graphic. Generate an impressive final well schematic with hi-resolution graphics
the link
best regards
