Thread: Drill Steam Test - how is this performed?
  1. Question Drill Steam Test - how is this performed?
    Generally this test is performed in an openhole well using drill pipes or it is performed in a cased / perforated well?
    Or maybe both situations are valid.
    Can anyone explain me?
    Thank you.
    Feb 2010
    Tierra
    There are a lot of materials available on google and from the renowned service providers like Schlumberger and Halliburton their knowledge base. Search on their sites and you will papers and real case histories on this topic
    A very good ppt on this topic
  5. Thank you for the short_cut. Quite informative.
    Still, there are described DST in cased hole.
    Could also be performed in uncased hole using land pakers?
  6. DST is performed for production formation whether cased or open. If more than one production zone with different pressures are there then multiply DST are performed.First the bottom production zone is test (normally open hole) and then the zone is isolated through bridge plug and above (cased) zones are perforated for DST.
  1. Drill Stem Test Design
    By gravitymass in forum Reservoir
    Last Post: 02-08-2014, 06:08 AM
  2. Drill Stem Test
    By pedroerico in forum Drilling And Workover
    Last Post: 08-14-2013, 04:26 PM
  3. ASME PTC 39 - Performance test codes for Steam traps
    By Rajiv_Harolikar in forum Pipeline And Fluid Flow
    Last Post: 06-09-2013, 07:09 PM
  4. [req] steam turbine test facility
    By wardhi_poenja in forum Mechanical Engineering
    Last Post: 09-24-2011, 01:28 PM
  5. Boiler Steam Test
    By tobbe in forum Pipeline And Fluid Flow
    Last Post: 05-17-2011, 10:47 AM
