Results 1 to 5 of 5
Thread: Article: pressure buildup
    You can view the page at
    Feb 2008
    Port Harcourt, Nigeria
    Cool Further
    Pressure buildup refers to rise in pressure in excess of that expected at normal system operating condition. If it continues unchecked, the system design pressure could be reached. And if the design (or maximum allowable working) pressure is exceeded, it can lead to failure(rupture) of equipment, line rupture.
    Normally industrial processes are designed to guard against pressure buildup by placing what we call system safeguards (protection) against pressure buildup. These safeguards provide at least 2 layers of protection to the system.
    Interpretation of pressure buildup done is by means of installed pressure guages on the equipment, (or on the line).
    I hope this is clear enough. Let me know if you need further explanation.
    thanks dear
    Actually i am not reservoir engineer
    i want to plot P/Z of a well
    But i cann;t calculate Z
    How can i do it?
    It needs psuedo critical pressure and pseudo critical temperatures?
  6. Quote Originally Posted by anjumbukhari
    thanks dear
    How can i do it?
    Hey dear,
    Can you tell us with which compostion of fluid you are dealing for this exercise.
    Because Critical pressure and critical temperature varies from compostion to composition.
    But if i am not wrong you must be having plenty of points against which you want to calculate P/Z.
    The easiest way is to calculate through PVTsim which provides Z in number of points within seconds.
    May be helpfull for you.
    Thanx
    Anu
    thanks dear i done it frm an excel sheet
    now concebtrating on pressure buildup
  1. Article: Pressure relief valves and set pressure
    By samabert in forum Home Articles
    Last Post: 01-08-2014, 06:43 PM
  2. Pressure buildup project
    By egpetkliye in forum Reservoir
    Last Post: 12-04-2013, 10:15 PM
  3. Article: pressure gradient
    By yasiobasio123 in forum Home Articles
    Last Post: 11-15-2013, 07:51 AM
  4. Replies: 0
    Last Post: 07-28-2011, 04:21 AM
  5. pressure buildup
    By anjumbukhari in forum Reservoir
    Last Post: 02-09-2011, 11:17 AM
