Wind power has long been considered a viable form of energy production. Although it doesn't generate pollution and has a number of other benefits, there are many drawbacks. Some of them include lack of predictability, high costs, noise, and environmental effects. This article will discuss some of the most important disadvantages of wind power.
Predictability
One of the main disadvantages of wind power is that wind is very unpredictable. Strength can vary from none to storm force. Therefore, wind turbines are unable to produce the same amount of electricity at the same time. Sometimes, there will be no electricity generated. Another drawback of wind power is the associated cost.
Cost
Another one of the disadvantages of wind power is the cost. Ideal locations for wind farms are usually very expensive to buy. Wind farms are also very expensive to maintain properly. In addition to the cost, another area of concern is the noise made by wind farms.
Noise
The level of noise made by turbines is also one of the disadvantages of wind power. One wind generator makes a low, swooshing sound 24 hours a day. Wind farms with many of these generators will make a lot of noise. Another problem with production is the amount of energy produced.
Production
Wind farms generally have a low energy output. While running at full speed, the largest turbine can only generate enough electricity to power 475 homes. Areas with a large population will need huge wind farms to generate power for a significant percentage of the population. Although wind power doesn't cause pollution while generating power, it does have a few negative impacts on the environment.
Environment
One of the final disadvantages of wind power is the effect on the environment. Birds like strong winds. It is very common for migrating birds to fly into wind turbines and get killed. Wind farms can also disturb your television reception if you live in the surrounding area.
