Thread: Level transmitters discrepancy
    Dear All,
    I'm C&I engineer working on Level transmitters Trouble shooting. The problem that:
    I have level transmitters mounted on the same vessel at the same height but presenting some discrepancies.
    I explain more the situation:
    Each vessel has two DP level transmitters , same model ( Rosemount ): One for the safety and the other for control.
    I will be very thankful if you give me your ideas and views concerning this.
    Best Regards,
    Hi,
    is the lower pressure port at the same pressure in both transmitters?
    The span, LRV and URV of the transmitters is the same?
    regards,
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    Quote Originally Posted by bitmap View Post
    Hi,
    regards,
    If everything is same then check, mounting zero.
    your problem will be solved.
    Thanks every body for your help,
    @ bitmap:
    not all of them having the same pressure tapping points.
    But the problem consists that the given values are not adequate. I explain, when LT01 displays 50% the other must dispaly 30% (theoretically) but really it displays 15% for example.
  1. Standard for designing displacer type level transmitters
    By f_nosferatu in forum Instrumentation & Control
    Last Post: 07-06-2013, 09:59 AM
  2. Article: Level transmitters discrepancy
    By Sabeur in forum Home Articles
    Last Post: 02-09-2011, 08:49 AM
  3. Use of Hastelloy C on transmitters sensor diaphragms
    By esganfia in forum Instrumentation & Control
    Last Post: 08-17-2009, 07:21 AM
  4. One RTD with two Transmitters
    By main_zia in forum Instrumentation & Control
    Last Post: 07-15-2009, 08:24 PM
