Thread: What is the difference between jacketted and double walled pressure vessels?
  1. Exclamation What is the difference between jacketted and double walled pressure vessels?
    Hello Everyone,
    I just recently recieved a proposal for Double walled pressure vessels. Everyone here is stating it is a jacketted vessels. They do sound the same but I just want to confirm whether the two are the same or not.
    The following is the excrept from the e-mail,
    Cryogenic Liquid Gas Storage Tank, Capacity= 5m3, type=Horizontal/Vertical double-walled, powder insulated/vacuum super insulation
    Also i would like to inquire what are the commonly used materials for it as I've not come across this sort of servicing vessels before. Also what code is recommended for it and the general guidelines to be followed.
    Anyone's input in this matter would be highly appreciated.
    fox
    May 2009
    Jubail Saudi Arabia
    Quote Originally Posted by foxawan View Post
    Hello Everyone,
    fox
    HI!
    You may use this code BS 7777 Part 2:1993 or later version, this applicable for that case..
    Cheers,
    duazo2009
  5. The hard section is selection material for support between inner and outer shell.
    If material didn't meet, there are condensation from outer shell.
  6. Do you have this code? Since i am working behind a firewall which doesn't allow downloading, it gets very tough to find standards that easily. If you can send it over to my e-mail address i would be most obliged.
    Farrukh
    Farrukh.hanif@descon.com
  1. Pressure Vessels External Pressure Technology (get book)
    By SHEMYY in forum Mechanical Engineering
    Last Post: 08-28-2015, 08:40 PM
  2. Replies: 1
    Last Post: 10-22-2014, 11:39 PM
  3. "Pressure Vessels: External Pressure Technology" by Carl T. F. Ross
    By vfq3481 in forum Mechanical Engineering
    Last Post: 11-07-2012, 10:06 AM
  4. Replies: 0
    Last Post: 01-03-2011, 12:59 PM
