Thread: Heat Exchanger Partition
    HI,
    I am trainee engineer and involved in heat exchanger design. I am confused with Partition in heat exchanger which is used for nos. of passes of fluid. so can you please let me understand about this?
    In general, if a shell and tube HX has two passes, then it will have one partition plate.
    For four passes and above, this criteria will depend upon tube layout, either it is Ribbon Type, Quadrant Type or Mixed/Combined one. For instance, if it is four pass ribbon type, then there will be two partition plates.
    The partition plates are placed in Front Head/End. You can also refer to Figure N-1.2 of TEMA (9th Ed.)for the location of partition plates.
    Hope this will solve your problem to a certain extent.
    Ayaz
  5. you must find de delta P, if is big to 10 Psi abs. the passes el is down, for exemple, if you have 4 passes then can put 2 , if is deltaPes little,down to 5 psi abs. if you have 2 passes, then you put 4 passes, the deltaP 5<deltap<10,
  1. Heat exchanger in platforms above similar Heat exchanger
    By rentecgomez in forum Oil And Gas Production
    Last Post: 05-16-2014, 06:49 AM
  2. Why we Need Pre Heat Exchanger
    By oilhunter in forum Oil And Gas Production
    Last Post: 11-22-2011, 12:11 PM
  3. heat exchanger
    By biswjeet in forum Mechanical Engineering
    Last Post: 06-25-2010, 01:11 PM
  4. heat exchanger
    By biswjeet in forum Oil And Gas Process
    Last Post: 03-27-2010, 04:25 PM
