Results 1 to 6 of 6
Thread: What is a Heat Pipe?
    A heat pipe is a simple device that can quickly transfer heat from one point to another. They are often referred to as the "superconductors" of heat as they possess an extra ordinary heat transfer capacity & rate with almost no heat loss.
    The idea of heat pipes was first suggested by R.S.Gaugler in 1942. However, it was not until 1962, when G.M.Grover invented it, that its remarkable properties were appreciated & serious development began.
    It consists of a sealed aluminum or copper container whose inner surfaces have a capillary wicking material. A heat pipe is similar to a thermosyphon. It differs from a thermosyphon by virtue of its ability to transport heat against gravity by an evaporation-condensation cycle with the help of porous capillaries that form the wick. The wick provides the capillary driving force to return the condensate to the evaporator. The quality and type of wick usually determines the performance of the heat pipe, for this is the heart of the product. Different types of wicks are used depending on the application for which the heat pipe is being used.
    Design Considerations
    The three basic components of a heat pipe are:
      1. the container
      2. the working fluid
      3. the wick or capillary structure
    Container
    The function of the container is to isolate the working fluid from the outside environment. It has to therefore be leak-proof, maintain the pressure differential across its walls, and enable transfer of heat to take place from and into the working fluid.
    Selection of the container material depends on many factors. These are as follows:
    • Compatibility (both with working fluid and external environment)
    • Strength to weight ratio
    • Thermal conductivity
    • Ease of fabrication, including welding, machineability and ductility
    • Porosity
    • Wetability
    Most of the above are self-explanatory. A high strength to weight ratio is more important in spacecraft applications. The material should be non-porous to prevent the diffusion of vapor. A high thermal conductivity ensures minimum temperature drop between the heat source and the wick.
    Working fluid
    A first consideration in the identification of a suitable working fluid is the operating vapour temperature range. Within the approximate temperature band, several possible working fluids may exist, and a variety of characteristics must be examined in order to determine the most acceptable of these fluids for the application considered. The prime requirements are:
    • compatibility with wick and wall materials
    • good thermal stability
    • wettability of wick and wall materials
    • vapor pressure not too high or low over the operating temperature range
    • high latent heat
    • high thermal conductivity
    • low liquid and vapor viscosities
    • high surface tension
    • acceptable freezing or pour point
    The selection of the working fluid must also be based on thermodynamic considerations which are concerned with the various limitations to heat flow occurring within the heat pipe like, viscous, sonic, capillary, entrainment and nucleate boiling levels.
    In heat pipe design, a high value of surface tension is desirable in order to enable the heat pipe to operate against gravity and to generate a high capillary driving force. In addition to high surface tension, it is necessary for the working fluid to wet the wick and the container material i.e. contact angle should be zero or very small. The vapor pressure over the operating temperature range must be sufficiently great to avoid high vapor velocities, which tend to setup large temperature gradient and cause flow instabilities.
    A high latent heat of vaporization is desirable in order to transfer large amounts of heat with minimum fluid flow, and hence to maintain low pressure drops within the heat pipe. The thermal conductivity of the working fluid should preferably be high in order to minimize the radial temperature gradient and to reduce the possibility of nucleate boiling at the wick or wall surface. The resistance to fluid flow will be minimized by choosing fluids with low values of vapor and liquid viscosities. Tabulated below are a few mediums with their useful ranges of temperature.
    Wick or Capillary Structure
    It is a porous structure made of materials like steel, alumunium, nickel or copper in various ranges of pore sizes. They are fabricated using metal foams, and more particularly felts, the latter being more frequently used. By varying the pressure on the felt during assembly, various pore sizes can be produced. By incorporating removable metal mandrels, an arterial structure can also be molded in the felt.
    Fibrous materials, like ceramics, have also been used widely. They generally have smaller pores. The main disadvantage of ceramic fibres is that, they have little stiffness and usually require a continuos support by a metal mesh. Thus while the fibre itself may be chemically compatible with the working fluids, the supporting materials may cause problems. More recently, interest has turned to carbon fibres as a wick material. Carbon fibre filaments have many fine longitudinal grooves on their surface, have high capillary pressures and are chemically stable. A number of heat pipes that have been successfully constructed using carbon fibre wicks seem to show a greater heat transport capability.
    The prime purpose of the wick is to generate capillary pressure to transport the working fluid from the condenser to the evaporator. It must also be able to distribute the liquid around the evaporator section to any area where heat is likely to be received by the heat pipe. Often these two functions require wicks of different forms. The selection of the wick for a heat pipe depends on many factors, several of which are closely linked to the properties of the working fluid.
    The maximum capillary head generated by a wick increases with decrease in pore size. The wick permeability increases with increasing pore size. Another feature of the wick, which must be optimized, is its thickness. The heat transport capability of the heat pipe is raised by increasing the wick thickness. The overall thermal resistance at the evaporator also depends on the conductivity of the working fluid in the wick. Other necessary properties of the wick are compatibility with the working fluid and wettability.
    The most common types of wicks that are used are as follows:
    Sintered Powder
    This process will provide high power handling, low temperature gradients and high capillary forces for anti-gravity applications. The photograph shows a complex sintered wick with several vapor channels and small arteries to increase the liquid flow rate. Very tight bends in the heat pipe can be achieved with this type of structure.
    Grooved Tube
    The small capillary driving force generated by the axial grooves is adequate for low power heat pipes when operated horizontally, or with gravity assistance. The tube can be readily bent. When used in conjunction with screen mesh the performance can be considerably enhanced.
    Screen Mesh
    This type of wick is used in the majority of the products and provides readily variable characteristics in terms of power transport and orientation sensitivity, according to the number of layers and mesh counts used.
    Working
    Inside the container is a liquid under its own pressure, that enters the pores of the capillary material, wetting all internal surfaces. Applying heat at any point along the surface of the heat pipe causes the liquid at that point to boil and enter a vapor state. When that happens, the liquid picks up the latent heat of vaporization. The gas, which then has a higher pressure, moves inside the sealed container to a colder location where it condenses. Thus, the gas gives up the latent heat of vaporization and moves heat from the input to the output end of the heat pipe.
    [link Point to another website Only the registered members can access] Heat pipes have an effective thermal conductivity many thousands of times that of copper. The heat transfer or transport capacity of a heat pipe is specified by its " Axial Power Rating (APC)". It is the energy moving axially along the pipe. The larger the heat pipe diameter, greater is the APR. Similarly, longer the heat pipe lesser is the APR. Heat pipes can be built in almost any size and shape.
    Applications
    Heat pipe has been, and is currently being, studied for a variety of applications, covering almost the entire spectrum of temperatures encountered in heat transfer processes. Heat pipes are used in a wide range of products like air-conditioners, refrigerators, heat exchangers, transistors, capacitors, etc. Heat pipes are also used in laptops to reduce the working temperature for better efficiency. Their application in the field of cryogenics is very significant, especially in the development of space technology. We shall now discuss a brief account of the various applications of heat pipe technology.
    Space Technology
    The use of heat pipes has been mainly limited to this field of science until recently, due to cost effectiveness and complex wick construction of heat pipes. There are several applications of heat pipes in this field like
    • Spacecraft temperature equalization
    • Component cooling, temperature control and radiator design in satellites.
    • Other applications include moderator cooling, removal of heat from the reactor at emitter temperature and elimination of troublesome thermal gradients along the emitter and collector in spacecrafts.
    Heat pipes for Dehumidification and Air conditioning
    In an air conditioning system, the colder the air as it passes over the cooling coil (evaporator), the more the moisture is condensed out. The heat pipe is designed to have one section in the warm incoming stream and the other in the cold outgoing stream. By transferring heat from the warm return air to the cold supply air, the heat pipes create the double effect of pre-cooling the air before it goes to the evaporator and then re-heating it immediately.
    Activated by temperature difference and therefore consuming no energy, the heat pipe, due to its pre-cooling effect, allows the evaporator coil to operate at a lower temperature, increasing the moisture removal capability of the air conditioning system by 50-100%. With lower relative humidity, indoor comfort can be achieved at higher thermostat settings, which results in net energy savings. Generally, for each 1° F rise in thermostat setting, there is a 7% savings in electricity cost. In addition, the pre-cooling effect of the heat pipe allows the use of a smaller compressor.
    Flexible Solutions
    Heat pipes are manufactured in a multitude of sizes and shapes. Unusual application geometry can be easily accommodated by the heat pipe’s versatility to be shaped as a heat transport device. If some range of motion is required, heat pipes can even be made of flexible material.
    Two of the most common are:
    Constant Temperature: The heat pipe maintains a constant temperature or temperature range.
    Diode: The heat pipe will allow heat transfer in only one direction.
    Mega Flats
    Flat heat pipes are typically used for cooling printed circuit boards or for heat leveling to produce an isothermal plane. Mega flats are several flat heat pipes sandwiched together.
    Some of the flat heat pipes manufactured are:
    XY Mega Flats: Surface maintained within .01° F isothermal with concentrated load centers. 6" X 6" Mega Flat: Dissipated 850 watts from a printed circuit board.
    Weight Reduction Mega Flats:
    Standard - aluminum construction.
    Lightweight - ½ the weight of aluminum.
    Very light weight - 1/3 the weight of aluminum.
    SEM C and SEM E Mega Flats in stock. Low and light weight coefficient of thermal expansion (CTE) Mega Flats - any CTE from 2 to 10. Alloy H: 70% more conductive than, or 40% less weight than copper clad invar.
    Cost Effectiveness of Heat Pipes
    The cost of heat pipes designed for laptop use is very competitive compared to other alternatives. Cost is partially offset and justified by improved system reliability and the increased life of cooler running electronics. Heat pipes, in quantity, cost a few dollars each while an entire cooling system will cost between $5 - $10 in production quantities, depending on the final design. Standard design products are available to reduce cost even further. Heat pipe manufacture has been a difficult area to compete in. Simple in concept, but difficult to apply commercially, the heat pipe is a very elusive technology & holds the key to the future of heat transfer & its allied applications.
    A device for transferring heat efficiently between two locations by using the evaporation and condensation of a fluid contained therein. Heat pipes have many applications in areas where reliable performance and low cost are of prime importance—for example, in electronics and heat exchangers. See also Heat exchanger.
    The heat pipe, the idea of which was first suggested in 1942, is similar in many respects to the thermosiphon. A large proportion of applications do not use heat pipes as strictly defined below, but employ thermosiphons ( illus. a), sometimes known as gravity-assisted heat pipes. A small quantity of liquid is placed in a tube from which the air is then evacuated, and the tube is sealed. The lower end of the tube is heated, causing liquid to vaporize and the vapor to move to the cooler end of the tube, where it condenses. The condensate is returned to the evaporator section by gravity. Since the latent heat of evaporation is generally high, considerable quantities of heat can be transported with a very small temperature difference between the two ends. Thus the structure has a high effective thermal conductance. The thermosiphon, also known as the Perkins tube, has been used for many years. A wide variety of working fluids have been employed, ranging from helium to liquid metals.
    Heat transfer devices. (a) Thermosiphon. (b) Heat pipe; it can be in any position, not just vertical as shown.
    One limitation of the basic thermosiphon is that in order for the condensate to be returned by gravitational force to the evaporator region, the latter must be situated at the lowest point. The heat pipe is similar in construction to the thermosiphon, but in this case provision is made for returning the condensate against a gravity head. A wick, for example a few layers of fine gauze, is commonly used. This is fixed to the inside surface of the tube, and capillary forces return the condensate to the evaporator ( illus. b). Since the evaporator position is not restricted, the heat pipe may be used in any orientation. If the heat pipe evaporator happens to be in the lowest position, gravitational forces will assist the capillary force. Alternative techniques, including centripetal forces and osmosis, may be used for returning the condensate to the evaporator.
    Capillary forces are by far the most common form of condensate return employed, but a number of rotating heat pipes are used for cooling of electric motors and other rotating machinery. In some applications a mechanical pump is used to return condensate in two-phase run-around coil heat recovery systems. While this may be regarded as a retrograde step, it is a much more effective method for condensate return than reliance on capillary forces.
    Applications are related to five principal functions of the heat pipe: separation of heat source and sink, temperature flattening, heat flux transformation, temperature control, and action as a thermal diode or switch. The two major applications, cooling of electronic components and heat exchange, can involve all of these features. In the case of electronics cooling and temperature control, all features can be important. In heat exchangers employing heat pipes, the separation of heat source and sink, and the action as a thermal diode or switch, are most significant.
  1. Compact plate heat exchangers used for refinery heat recovery
    By Freeman in forum Petroleum Refining
    Last Post: 05-06-2018, 02:50 PM
  2. Steam trap type in heat tracing of heat sensitive material
    By gmbobs in forum General Engineering
    Last Post: 05-28-2013, 02:15 PM
  3. What is a Heat Pipe?
    By Freeman in forum Mechanical Engineering
    Last Post: 12-07-2008, 02:05 AM
