Thread: WB36 drum shell cold craKing problem?
    I just want to discuss about something...my firm always doing drum shells (for boliers) of 15NiCuMoNb5 (WB36) material, and there's almost every time same problem - cold cra-c-k-ings after finally pwht. we finally find some solution...when there's a late hold cra-c-k-ings (48 hrs. after pwht - NDT testing shows)...:
    1 - all imperfections must be removed with grinding
    2 - the circles around the imperfections must be preheated at temperatures >150°C, in diameter of minimum 500 mm around the removed imperfections
    3 - repairs must be done in horisontal welding position (PC) - off course, the drum shall be rotated to make possible to the welder to weld in PC position
    4 - using of DMO-Kb electrode, welding without of waving electrodes, just straight pulling, in few passes
    5 - the last electrode pass must be slowly and carefully grinded
    6 - then comes more heating, without interruption of already preheated tempetature of > 150°C; the heating speed shouldn't be over 40°C per 1 hour, and then when it reach 280-300°C that temperature must be keeped for 2 hrs and then comes slowing down to the room temperature, again cooling speed must be slowed, not so slow as heeting rate, but..50-60°C per hour is maximum
    7 - then comes NDT; only with dry magnetic particles (dry fluxes are more then wishfull), and NDT must be performed on whole drum shell, not just places where the imperfections was
    8 - pwht comes; 580-600°C, depends on drum thickenss; mostly it's 2 hrs.
    9- 48 hrs. after finishing pwht - again comes magnetical particle NDT with dry things, without hydrogen content
    so...does anyone have experince with this WB 36 drums? and how do you solved the cold crac-king problems?
    Do you have a problem with the filler material?
    I mean do you re-drying the electrodes/ sub-arc flux?
  5. I don't know this particular material, however, the following items should be met if you deal with high Ni QT/NT materials:
    Check the maxium heat input does not exceed the maximum qualified value as per PQR.
    Interpass temperature must not exceed the maximum value as per PQR
    Assuming you are using SMAW, make sure low hydrogen electrode is used.
    If the material is QT/NT you need to make sure that the PWHT temperature does not exceed tempering temperature of the base metal.
    Cheers,
  1. SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    By hammad_nrl in forum Mechanical Engineering
    Last Post: 04-10-2013, 06:06 AM
  2. Replies: 3
    Last Post: 04-03-2013, 07:00 AM
  3. req: V&M books : WB36 book
    By BornToSin in forum Materials Science &Corrosion
    Last Post: 11-24-2010, 02:41 AM
  4. Dear ALi Flare K.O. drum and Seal drum sizing
    By buterfly385 in forum Oil And Gas Process
    Last Post: 06-11-2010, 12:43 PM
