Any pro can share the following papers
Thank you very much.
Woodside O. Protect centrifugal pumps from low flow, chemical engineering progress, June 1995, P.53
Woodside O. warm up centrifugal pumps properly. chemical engineering progress January 1996, P.42
Neerken R F. How to select and apply positive-displacement rotary pumps, chemical engineering, April 7, 1980 P.76
Breneisen S. Minimize metering pump problems, Hydrocarbon Processing, July 1996, P.47
Cody D. J. Selecting positive displacement pumps, Chemical engineering, July 22 1985 P.38
Lima J. Meet your metering pump objectives, chemical engineering progress, Feburary 1992 P.34
Poynton J P. Basics of reciprocating metering pumps, Chemical engineering, May 21 1979, P.156
Poynton J P. Mtering pumps: types and applications, Hydrocarbon Processing, November 1981, P.279
Kern R. pump piping design, chemical engineering, october 11, 1971
Dimoplan W. What process engineers need to know about compressors, hydrocarbon processing, 1978, P.221
Lapina R P. How to use the performance curves to evaluate behavior of centrifugal compressors, chemical engineering, January 25, 1982. P.86
Ryans J. L. croll S. Selecting vacuum systems chemical engineering December 14,1981 P.72
Birgenheier D.B. Designing steam jet vacuum systems, Chemical engineering July,1993
Croll S. Properly specify vacuum system Chemical engineering January,1996 p18
Improving vacuum system Chemical engineering September 2000 p86
Kern R. Arrangements of process and storage vessels, chemical engineering November 7, 1977 P.93
Wong W. Sizing for exchanger tube ruputure Hydrocarbon Processing, February 1992 P.59
Wong W. Capacity credit calculation for exchanger tube ruputure Hydrocarbon Processing December 1992 P.89
Cppigncaux P. Compare codes for relief valve calculation, Hydrocarbon processing August 1980 P.69
Kern R. Pressure relief valves for process plant, chemical engineering progress, November 1980 P.51
Cox O J. Weirick M. I. Sizing safety valve inlet lines, chemical engineering progress, November 1980 P.51
Westman M. A. rapidly Design Safety relief valve Inlet piping systems, chemical engineering progress March 1997 P.80
