Tutorial : How to start a running job with the OLGA GUI
The input system of Olga consists in six files. Input file 1 & 2 are always required while 3,4,5 & 6 are optional.
For our test, only input files 1 &2 have been taken into consideration.
File 1 (SimName.inp): General case definition: name, reference, geometry, operational conditions, output variables. With the Graphic User Interface (GUI) this file is automatically generated.
File 2 (SimName.tab): Fluids properties definition ( also called PVT file ) .You have to click on Case(1) to open your file in order to verify all your parameters.
After that you can click on Keywords (2) to open the keyword window : you will be able to enter all the data needed for the case by clicking on the desired key words. For a simple case it is not necessary to go through all the keywords. Just follow step by step the procedure :
