Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: PDMS! I can't cr@ck with the tutor??
    [link Point to another website Only the registered members can access] ////
    PLACE THE FILE *****-116SP47.EXE IN THE C:\AVEVA\PDMS11.6SP4 DIRECTORY
    RUN THE *****.
    YOU WILL GET ERROR FOR DES.DLL CLICK OK AND CLICK NEXT
    ALL FILES WILL *****ED. EXCEPT DES.DLL, ISS.DLL AND ISD.EXE
    RUN ***** DES_DLLSP4.8 FOR *****ING DES.DLL
    RUN ***** ISS_DL_SP4.8 FOR *****ING ISS.DLL
    REPLACE ISD.EXE WITH THE ISD.EXE PROVIDED WITH THIS.
    other tutor.
    1. copy cra.exe and pdms116.crk to the directory you installing pdms11.6
    2. double click cra.exe to run it in windows
    3.cra.exe will switch to dos mode
    4. in dos mode press RETURN key to continue
    5. Press RETURN key to repley its ok until to the end
    6. press ESC to back
    7. press F10 to exit
    8. enjoy !
    NOTES:
    in DOS mode,mouse do not work in CRA.EXE,use RETURN
    key instead
    [link Point to another website Only the registered members can access] info@pdms.ir
    I thinks Tutor have problems or too short!
    Help me! I need for new job appllication!
    Please, If you know give me some advices!
    YM:shareit_fr
  3. Quote Originally Posted by vatcpr View Post
    RUN THE *****.
    other tutor.
    8. enjoy !
    NOTES:
    key instead
    YM:shareit_fr
    Sorry for checking this post so late, this being a different thread could not get attention.
    With the files provided by me, you do as I said & it will work.
    For pdms.ir ***** to work, you need .net framework 2.0
    mouse will not work, you have to use function keys,
    F1, F2 and ---- F10
    I think F10 is for quit.
    F2 is for *****
  5. Thankyou very much
  6. Hi, I got following error message when I install sp 4.8:
    System.AccessViolationException:Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    at DLL_Init.Initialise<Boolean, Boolean, Boolean, SByte*>
    at Aveva.PDMS.Utility.Startup.PDMS.Start<Boolean isGraphics, Boolean isBatch, Boolean isNoConsole, String logfile>
    at AVEVA.PDMS.Presentation.Monitor.mon.Main<String[]Args>
    :Fatal Error
    Please help me
  7. erick2006 i have the same problem with this program, how did you fix it?
  9. This is PDMS 12:
    [link Point to another website Only the registered members can access] Thanks
    Quote Originally Posted by Supportall.4marine View Post
    This is PDMS 12:
    Thx pal alot,...but i guess you should maybe post your kind link ELSEWHERE/on other threads (it's hardly visible here...no?)
    And what's the Password to extract it plz (the RAR archive is protected) ??
    Regards.
    please can you send the password for the rar file to my mail soloweber@yahoo.com
    Aug 2010
    Singapore, Singapore, Singapore
    Hello, i have the same problem as eric2006, how to solve this problem? Thanks.
  13. where is the password???
  14. #11
    pdms video training
  16. I cant install correctly PDMS 12 sp6 in window 7.
    i dont know what is the problem ----- or window 7 itself?
    please anyone help me to find out problem?
    how am i run PDMS sp6 run in to the window 7?
    Thanks in advance
  1. Replies: 5
    Last Post: 06-16-2016, 12:56 PM
  2. Autocad tutor E book
    By ericssion in forum Mechanical Engineering
    Last Post: 08-26-2012, 10:17 AM
  3. matlab tutor.
    By olumide_12 in forum Computer & Internet
    Last Post: 09-28-2011, 06:03 AM
