Page 1 of 2 1 2 LastLast
Results 1 to 12 of 23
Thread: Aspen Engineering suite 2006 : Installation step-by-step guide
    Question Aspen Engineering suite 2006 : Installation step-by-step guide
    To all who had managed to download & install all the modules of Aspen Suite 2006
    ( or at least managed to install Aspen Plus, Aspen Process Manual, Aspen Process Tools, etc ) ,
    pls help us newbies on the step-by-step procedures.
    The suite contain almost all the Aspen modules ( roughly about 714, i think ) & getting
    thru the installation is the PROBLEM.
    I am seeing recommendation in bits & pieces everywhere in almost every thread & I hope that
    this thread would ease all the newbies on procedures.
    Just my 2 cents.
    Thank you
    Cheers.
  3. thank you
    Thumbs up Step-by-Step procedure for installing AspenOne 2006
    Dear,
    Here's the simple procedure of installing AspenOne Engineering suite:
    1. First copy the directory Magnitude to one of the directories in your hard drive and remember the location.
    2. Then execute ASPEN_LicGen.exe by double clicking in the file.
    3. The license generator takes some time to generate the license file and the license file is created inside the Magnitude directory itself after some time. Once you are prompted that the license file is created, close the ASPEN_LicGen window (a kernel window). The size of the license file is ~84 kB.
    4. Then, insert the DVD-DL in which you have burned Aspen Engineering Suite into your DVD drive, or mount the iso file in any virtual drive. The DVD browser is started automatically by autoplay feature in your system. In case the autoplay fails, manually execute DVDBrowser from the root directory of the DVD.
    5. The DVD browser automatically prompts you to search for the license. Browse to the Magnitude directory in your hard drive in which the license file is created and point to the license file in the Browse window. Then the license manager initializes the license file and it lists all the licensed softwares. Please be patient as it takes some time to enlist the licensed softwares. It obtains license for 710 softwares inside the Engineering suite, if everything goes okay.
    6. Then select the required category of suite you wish to install and press install. That's all; you're done. Enjoy the suite.
    Yours,
    Nskvc
    Jul 2007
    Chennai, Tamil Nadu, India
    Thanks for the procedure. Will it work in vista ?
    Apparently 2006 could not be run in vista. I think v7 version is the vista version.
    But below is an excerpt from another forum pertaining to running it on vista.
    Haven't tried ( no vista )......try at your own risk
    ......if your pc has the power you can install a virtual machine running windows xp using microsoft virtual pc available for free on their site.
    you can then run vista, have an xp machine in it running aspen........
    ciao
    Process Manual module.
    Anyone has any procedures as to how to fully install it ? How to use it even after it has been installed ?
  10. Aspen 2006 installation ,after showing the License path ,it displayed the 710 files which are licensed, but its not directing to install, it's asking to select DVD no's. how to over come this can you please suggest me.
    Sep 2008
    CORNER OF WEST BORNEO
    Quote Originally Posted by nskvc View Post
    Dear,
    Yours,
    Nskvc
    I have Finish Installation ASPEN, when i open aspen properties in microsoft Excel (there is trouble when i calling "ASPEN PROPERTIES HELP"...Windows prompt me Cannot Find APR_G3.HLP and reinstall ASPEN"...But i was check in installation dir of my ASPEN properties there is APR_G3.chm not extention .hlp). could u help me...
    Sep 2008
    Quote Originally Posted by hyuda View Post
    Mr NSKVC: Sorry my english may be bad...i hope u can understand what i mean...Thank's for your help bro...help me to solve it
  13. Thanks for your installing guide, but when I finished the installed, there is trouble: aspen plus version 20.0 could not locate the registry entry for the data browser menu database. data entry and results forms will not be available.
    could u help me.
  14. #11
    Thank you
  16. Guys, I cannot seem to install Aspen Process Manual. Kept getting stuck when trying to install proman. Can you shed some light on how to go about it?
  1. Replies: 11
