Thread: Tolerance for wall thickness
    Hi
    I want to ask...............How to calculate the wall thickness for pipe including the tolerance mil (table 11) as per as API 5L 44Th Edition ( October 2008).
  3. When I calculate the wall thickness, I take the smallest POSSIBLE thickness. If the published thickness was 0.25" and mill tolerance was 12.5%, I would use (1-.125)*.25"=0.21875" as the smallest thickness.
    If I was calculating the thickness of the pipe based on 31.1, 31.3, 31.8, etc. , I would make sure I chose a pipe (don't forget to subtract mill tolerances, thread allowances, if needed and corrosion allowances) whose thickness was greater than the calculated thickess above.
    am I confusing?
    Question offset between 2 longitudinal seam
    Dear All members,
    I would like to know what is the permissible limit of offset when joining between 2 welded pipe(longitudinal seam). ASME VIII clearly stated but B31.3 silent on it. Any other reference, code or recommended practice that i can refer to it. If any could you share with me. Thank in advance for you cooperation
    Suhairi
    Please see the following CR4 Thread with a solved example per ASME code indicating how to calculate the min. pipe wall thickness, taking into consideration the tolerance:
    The pipe wall thickness tolerance as per API 5L is in accordance with Table 9, see the following CR4 Thread :
  1. Pipe wall thickness as per EN 13480-3
    By pico5892 in forum Engineering Spreadsheets & Presentations
    Last Post: 05-09-2025, 08:40 PM
  2. Stress value in Wall Thickness equation in B31.3
    By SMechanica in forum Pipeline And Fluid Flow
    Last Post: 01-08-2014, 01:59 AM
  3. Stress value in Wall Thickness equation in B31.3
    Last Post: 01-06-2014, 08:09 PM
  4. Minimum Wall Thickness Criteria
    By sfol55 in forum Pipeline And Fluid Flow
    Last Post: 08-05-2013, 10:49 PM
  5. Wall Thickness
    By Tito Saul in forum Pipeline And Fluid Flow
    Last Post: 07-30-2013, 04:06 AM
