Dear All,
I want to open hysys build 6728, i had hysys build 5029.Is there any method to open this build 6728 with my existing build.Please guide me.
Thanks in Advance.
Abdul
Dear All,
Thanks in Advance.
Abdul
Please help me, i am waiting for your valuable reply
sir what do you mean by build. is your problem is that you want to open one version of hysys file into other version of hysys or some thing else.
Dear Sharmeen,
I have HYSYS 3.2, when I came to open one hysys file it shows one message that " the build 6728 is not opened by 5029" It means I have hysys belongs to build 5029 & I try to open is of advanced version belongs to build 6728. So will you please help to open the newer version file with my old build.
Thanks & Regards,
Abdu
Primero tienes que abrir el caso con el hysys "build 6728" (para ello tienes que tener el hsysys build 6728), luego lo guardas con el formato XML (Save As..), este formato puedes seleccionarlo de la lista desplegable que se encuentra en la parte inferior de donde se escribe el nombre del archivo. Para abrir con hysys 3.2 tiene que abrir el hysys 3.2, luego das la opción de abrir y en tipo de archivo seleccionas XML y te mostrara todos los archivos XML y escoges el archivo que guardaste. Hysys normalmente guarda los casos en formato HSC.
Dear Sir,
Will you please post the reply in English, I am not able to understand your reply.Please help me.
Hi Abdul Will u please give any link to download HYSYS 3.2 version, it will be a great help for me.
First you have to open the case with HYSYS "build 6728" (to do so you have to have the hsysys build 6728), then save it with the XML format (Save As ..), this format you can select the drop-down list that is at the bottom of where he writes the file name. To open with HYSYS 3.2 has to open the HYSYS 3.2, then the option of opening days and choose XML file type and will show all files and choose XML file that stored it. HYSYS normally keeps the cases as a HSC.
NOTE: I'm Sorry, my english es bad
Sir but where will I get that Hysys build 6728. Is there any link to download that freely? Please guide me sir.
Links:
AspenTech Aspen Engineering Suite 2006 (Hysys Buid 6728)
***** only
many links on RapidShare, Medifile......
password: vndownload.org
Rapidshare
Code:
sfv:
Mediafire
Code:
sfv
ifile.it
Code:
sfv
zshare
Code:
sfv
depositfiles
Code:
sfv
netload
Code:
Links:
AspenTech Aspen Engineering Suite 2006.5 (Hysys Build is greater than 6728 (I don't remember the build)
RapidShare
MIRROR on Megaupload
I Hope this helps...
Some Aspen HYSYS release build numbers and versions:
Build Version
6924 2006.5 with CP1
6924 2006.5
6729 2006 with CP2
6729 2006 with CP1
6728 2006
6617 2004.2 with CP5 + ***** 6
6616 2004.2 with CP4
6615 2004.2 with CP3
6614 2004.2 with CP2
6613 2004.2 with CP1
6612 2004.2
6511 2004.1 with CP1
6510 2004.1
6150 2004
5029 3.2
4815 3.1
4602 3.0.1
3874 2.4.2
3870 2.4.1
3806 2.2.2
3797 2.2
3216 2.1.3
3198 2.1.1
Thorem
