Results 1 to 6 of 6
Thread: 2 Incomer :1 Buscoupler Power Control Center (PCC)
    Oct 2009
    Dehli, Delhi, India, India
    Blog Entries
    1
    Dear All,
    Am facing a problem with 2 IC:1BC PCC which am unable to rectify Request Please help.
    1] Autochange over from BUS A is normal. (IC-1 trip on Undervoltage Buscoupler close).
    2] Autochange over from BUS B is normal (with only 2 Motor running).(IC-2 trip on Undervoltage Buscoupler close).
    3] If more than 3 Motors are running Bus transfer from IC-1 to BC is normal while
    IC-2 to BC is creating problem. Buscoupler close & open frequently. Please
    note UV in Motor relays are disable. None of the relays are registering any alarm
    or fault. SEL-751 is used for IC & BC Feeder Protection.
    4] I had checked the scheme , Relay Logic & Protections settings & found in line.
    5] Some ACB open on surges without any fault on relays.
    6] Am in opinion that Motor Residual Voltage is causing this problem but stuck up
    for the cause of BC tripping.Am attaching BC tripping scheme for your reference, There are two trip commands,
    a] K21 is BC relay & trip logic for same is 50P1T or 51P1T or 50N1T or 51N1T or G1T only.
    b] K27 is Master trip & hand reset. There is no other source for tripping.
    Any Suggestions.
  3. Pls upload control wiring of PMCC, then I suggest u……
    Oct 2009
    Blog Entries
    1
    how to attach file here?
    Hi Friend
    Please send the control circuit diagram to me on my email (smzakaullah@yahoo.com) and I will try to help you.
    Oct 2009
    Blog Entries
    1
    Thanks Mr.Smzakaullah I had solved the problem.
    Quote Originally Posted by raj151857 View Post
    Hi raj151857,
    Can you share the diagram along with the solution.
  1. Replies: 13
    Last Post: 07-11-2018, 03:44 AM
  2. Center of gravity & buoyancy
    By pd_hari in forum Engineering Programming
    Last Post: 07-13-2013, 12:18 PM
  3. [ebook] Power Distribution and Control
    By br1x in forum Electrical & Power Engineering
    Last Post: 07-12-2011, 01:51 AM
