Hello,
I need urgently the following British Standard :
BS 2790
BS 1113
BS 2486
Thanks in advance
Hello,
BS 2790
BS 1113
BS 2486
Thanks in advance
1.BS 1113:1999
15-Nov-1999
Replaced by BS EN 12952-10:2002 BS EN 12952-1:2001 , BS EN 12952-2:2001 , BS EN 12952-3:2001 , BS EN 12952-4:2000 , BS EN 12952-5:2001, BS EN 12952-6:2002 , BS EN 12952-7:2002 , BS EN 12952-11:2007 ,
Specification for design and manufacture of water-tube steam generating plant (including superheaters, reheaters and steel tube economizers)
BS EN 12952-1-2002 General
BS EN 12952-2-2002 Material of Boiler
BS EN 12952-3-2001 Design & Calculation of pressure parts
BS EN 12952-4-2000 Boiler life expectation calculation
BS EN 12952-5-2001 Construction of pressure part of Boiler
BS EN 12952-6-2002 Inspection during Construction
BS EN 12952-7-2002 Equipment for the Boiler
BS EN 12952-8-2002 Firing System for Liquid and Gas
BS EN 12952-9-2003 Firing system for pulverizer solid fuel
BS EN 1295BS EN 12952-11-2007 Limiting device of the boiler2-10-2002 Safegusrd against excessive pressure
BS EN BS EN 12952-13-2003 Requirement for flue gas cleaning systems12952-12-2003 Boiler feed water quality requirement
BS EN 12952-14-2004 DENOX system using liquid Ammonia
BS EN 129BS EN 12952-15-2003 Acceptance Test
BS EN 12952-16-2003 Requirement for Grate and Fluidize Bed
BS EN 12952 - Water Tube Boiler and Auxilliary Installation.rar 8.578 MB
2.BS 2790:1992
02-Jan-1992
Replaced by BS EN 12953-1:2002 BS EN 12953-2:2002 , BS EN 12953-3:2002 , BS EN 12953-4:2002 , BS EN 12953-5:2002 , BS EN 12953-6:2002, BS EN 12953-8:2001 ,
Specification for design and manufacture of shell boilers of welded construction
BS EN 12953-1 2002 Part 1 General
BS EN 12953-2 2002 Part 2 Materials for pressure parts of boilers and accessories
BS EN 12953-3 2002 Part 3 Design and calculation for pressure parts
BS EN 12953-4 2002 Part 4 Workmanship and construction of pressure parts of the boiler
BS EN 12953-6 2002 Part 6 Requirements for equipment for the boiler
BS EN 12953-7 2002 Part 7 Requirements for firing systems for liquid and gaseous fuels for the boilers
BS EN 12953-8 2001 Part 8 Requirements for safeguards against excessive pressure
BS EN 12953-10 2003 Part 10 Requirements for feedwater and boiler water quality
BS EN 12953 - Shell Boiler.rar 3.894 MB
3. BS 2486-1997 Treatment of water for steam boilers and water heaters.pdf 0.418 MB
Hi friend ... I need "ISO 179-1" Edition 2010 , do you have it available?
please send to ahmadi_edu@yahoo.com
Thanks alot
Thank you for all but I didnot found BS 113 and BS 2790.
I need them also
I need BS 4994 please help.
thanks in advance
I need BS 2000 all the help would be appreciated.
Wsalam
Dear All
I need BS 4994 New edition in this regard your help would be appreciated.
Can i Have BS 4994
BS 4994:1987 – Specification for design and construction of vessels and tanks in reinforced plastics
BS 4994-1987 Specification for design and construction of vessels and tanks in reinforced plastics.pdf 5.916 MB
Thanks a lot for BS 4994.
