Page 1 of 2 1 2 LastLast
Results 1 to 12 of 23
Thread: AWS great collection
    this here IS not my links; I prefer if I found useful book or standard at the internet to download it and reupload it at rapidshare, or upload some standards I have and that I couldnt find on internet, so..the credits go to the original uploader
    “ AWS A5.1 Specification for Carbon Steel Electrodes for Shielded Metal Arc Welding
    AWS A5.2 Specification for Carbon and Low Alloy Steel Rods for Oxyfuel Gas Welding
    AWS A5.3 Specification for Aluminum and Aluminum Alloy Electrodes for Shielded Metal Arc Welding
    AWS A5.4 Specification for Stainless Steel Electrodes for Shielded Metal Arc Welding
    AWS A5.5 Specification for Low-Alloy Steel Electrodes for Shielded Metal Arc Welding
    AWS A5.6 Specification for Covered Copper and Copper Alloy Arc Welding Electrodes R(1991)
    AWS A5.7 Specification for Copper and Copper Alloy Bare Welding Rods and Electrodes R(1991)
    AWS A5.8 Specification for Filler Metals for Brazing and Braze Welding
    AWS A5.9 Specification for Bare Stainless Steel Welding Electrodes and Rods
    AWS A5.10 Specification for Bare Aluminum and Aluminum Alloy Welding Electrodes and Rods
    AWS A5.11 Specification for Nickel and Nickel Alloy Welding Electrodes for Shielded Metal Arc Welding
    AWS A5.12 Specification for Tungsten and Tungsten Alloy Electrodes for Arc Welding and Cutting
    AWS A5.13 Specification for Solid Surfacing Welding Rods and Electrodes R(1989)
    AWS A5.14/A5.14MSpecification for Nickel and Nickel-Alloy Bare Welding Electrodes and Rods
    AWS A5.15 Specification for Welding Electrodes and Rods for Cast Iron
    AWS A5.16 Specification for Titanium and Titanium Alloy Welding Electrodes and Rods
    AWS A5.17/A5.17MSpecification for Carbon Steel Electrodes and Fluxes for Submerged Arc Welding
    AWS A5.18 Specification for Carbon Steel Electrodes and Rods for Gas Shielded Arc Welding
    AWS A5.19 Specification for Magnesium Alloy Welding Electrodes and Rods
    AWS A5.20 Specification for Carbon Steel Electrodes for Flux Cored Arc Welding
    AWS A5.22 Specification for Stainless Steel Electrodes for Flux Cored Arc Welding and Stainless Steel Flux Cored Rods for Gas Tungsten Arc Welding
    AWS A5.23 Specification for Low Alloy Steel Electrodes and Fluxes for Submerged Arc Welding
    AWS A5.24 Specification for Zirconium and Zirconium Alloy Welding Electrodes and Rods
    AWS A5.25 Specification for Carbon and Low Alloy Steel Electrodes and Fluxes for Electroslag Welding
    AWS A5.26 Specification for Carbon and Low Alloy Steel Electrodes for Electrogas Welding
    AWS A5.28 Specification for Low-Alloy Steel Electrodes and Rods for Gas Shielded Arc Welding
    AWS A5.29 Specification for Low Alloy Steel Electrodes for Flux Cored Arc Welding R(1989)
    AWS A5.30 Specification for Consumable Inserts
    AWS A5.31 Specification for Fluxes for Brazing and Braze Welding
    AWS A5.32 Specification for Welding Shielding Gases
    AWS A9.1 Standard Guide for Describing Arc Welds in Computerized Material Property and Nondestructive Examination Databases
    AWS A9.2 Standard Guide for Recording Arc Weld Material Property and Nondestructive Examination Data in Computerized Databases
    AWS B1.10 Guide for the Nondestructive Inspection of Welds (Supersedes AWS B1.0-77) R(1992)
    AWS B1.11 Guide for the Visual Inspection of Welds
    AWS "B2.1 Standard for Welding Procedure and Performance Qualification Replaces AWS D10.9; Reprinted with Errata May 1997"
    AWS B2.1.001 Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel, (M-1/P-1, Group 1 or 2), 3/16 Through 3/4 Inch, in the As-Welded Condition, with Backing
    AWS B2.1-1-016Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E7018, As-Welded or PWHT Condition
    AWS B2.1-1-017Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E6010, As-Welded or PWHT Condition
    AWS B2.1-1-018Standard Welding Procedure Specification (WPS) for Self-Shielded Flux Cored Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E71T-8, As-Welded Condition
    AWS B2.1-1-019Standard Welding Procedure Specification (WPS) for CO2 Shielded Flux Cored Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E70T-1 and E71T-1, As-Welded Condition
    AWS B2.1-1-020Standard Welding Procedure Specification (WPS) for 75% Ar/25% CO2 Shielded Flux Cored Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E70T-1 and E71T-1, As-Welded or PWHT Condition
    AWS B2.1-1-022Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E6010 (Vertical Uphill) Followed by E7018, As-Welded or PWHT Condit
    AWS B2.1-1-026Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E6010 (Vertical Downhill) Followed by E7018, As-Welded or PWHT Cond
    AWS B2.1-1-027Standard Welding Procedure Specification (WPS) for Self-Shielded Flux Cored Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 3/4 Inch Thick, E71T-11, As-Welded Condition
    AWS B2.1-1-201Standard Welding Procedure Specification (WPS) Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 3/4 Inch Thick, E6010 (Vertical Uphill) Followed by E7018 (Vertical Uphill), As-Welded Co
    AWS B2.1-1-202Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 3/4 Inch Thick, E6010 (Vertical Downhill) Followed by E7018 (Vertical Uphill), As-Wel
    AWS B2.1-1-203Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 3/4 Inch Thick, E6010 (Vertical Uphill), As-Welded Condition, Primarily Pipe Applicat
    AWS B2.1-1-204Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 3/4 Inch Thick, E6010 (Vertical Downhill Root with the Balance Vertical Uphill), As-W
    AWS B2.1-1-205Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E6010 (Vertical Uphill) Followed by E7018 (Vertical Uphill), As-Wel
    AWS B2.1-1-206Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E6010 (Vertical Downhill) Followed by E7018 (Vertical Uphill), As-W
    AWS B2.1-1-207Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, ER70S-2, As- Welded or PWHT Condition, Primarily Pipe Applications
    AWS B2.1-1-208Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, E7018, As-Welded or PWHT Condition, Primarily Pipe Applications
    AWS B2.1-1-209Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding Followed by Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, ER70S-2 and E7018, As-Welded o
    AWS B2.1-1-210Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding with Consumable Inserts of Carbon Steel (M-1/ P-1/S-1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick, INMs-1 and ER70S-2, As-Welded or PWHT Condit
    AWS B2.1-1-211Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding with Consumable Inserts Followed by Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S- 1, Group 1 or 2), 1/8 Through 1-1/2 Inch Thick INMs-1
    AWS B2.1.006 Standard Welding Procedure Specification (WPS) for Gas Metal Arc Welding of Carbon Steel to Austenitic Stainless Steel (M-1 to M-8 or P-8), 10 Through 18 Gage, in the As-Welded Condition, with or without Backing
    AWS B2.1.007 Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding of Galvanized Steel, 10 Through 18 Gage, in the As-Welded Condition, with or without Backing
    AWS B2.1.008 Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding of Carbon Steel (M-1, Group 1), 10 Through 18 Gage, in the As-Welded Condition, with or without Backing
    AWS B2.1-8-024Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding of Austenitic Stainless Steel (M-8/P-8/S-8, Group 1), 1/8 Through 1-1/2 Inch Thick, As-Welded Condition
    AWS B2.1-8-025Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding Followed by Shielded Metal Arc Welding of Austenitic Stainless Steel (M-8/P-8/S-8, Group 1), 1/8 Through 1-1/2 Inch Thick, As-Welded Condition
    AWS B2.1.009 Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding of Austenitic Stainless Steel (M-8 or P-8), 10 Through 18 Gage, in the As-Welded Condition, with or without Backing
    AWS B2.1.010 Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding of Carbon Steel to Austenitic Stainless Steel (M-1 to M-8 or P-8), 10 Through 18 Gage, in the As-Welded Condition, with or without Backing
    AWS B2.1.011 Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Galvanized Steel, 10 Through 18 Gauge, in the As-Welded Condition, with or without Backing
    AWS B2.1.012 Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel, (M-1, Group 1), 10 Through 18 Gauge, in the As-Welded Condition, with or without Backing
    AWS B2.1.013 Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Austenitic Stainless Steel, (M-8/P8) 10 Through 18 Gauge, in the As-Welded Condition, with or without Backing
    AWS B2.1.014 Standard Welding Procedure Specification (WPS) for Shielded Metal Arc Welding of Carbon Steel to Austenitic Stainless Steel, (M-1 to M-8 or P-8), 10 Through 18 Gauge, in the As-Welded Condition, with or without Backing
    AWS B2.1.015 Standard Welding Procedure Specification (WPS) for Gas Tungsten Arc Welding of Aluminum, (M-22 or P-22), 10 Through 18 Gauge, in the As-Welded Condition, with or without Backing
    AWS B2.2 Standard for Brazing Procedure and Performance Qualification
    AWS B4.0 Standard Methods for Mechanical Testing of Welds
    AWS B5.9
    AWS C1.1 Recommended Practices for Resistance Welding
    AWS C1.3 Recommended Practices for Resistance Welding Coated Low Carbon Steels R(1987)
    AWS C2.14 Corrosion Tests of Flame-Sprayed Coated Steel 19-Year Report
    AWS C2.16 Guide for Thermal-Spray Operator Qualification
    AWS C2.18 Guide for the Protection of Steel with Thermal Sprayed Coatings of Aluminum and Zinc and Their Alloys and Composites
    AWS C3.2 Standard Method for Evaluating the Strength of Brazed Joints in Shear R(1992)
    AWS C3.4 Specification for Torch Brazing
    AWS C3.7 Specification for Aluminum Brazing
    AWS C3.8 Recommended Practices for Ultrasonic Inspection of Brazed Joints
    AWS C4.2 Operator's Manual for Oxyfuel Gas Cutting
    AWS C4.3 Operators Manual for Oxyfuel Gas Heating Torch Operation
    AWS C5.1 Recommended Practices for Plasma-Arc Welding
    AWS C5.2 Recommended Practices for Plasma Arc Cutting R(1994)
    AWS C5.3 Recommended Practices for Air Carbon Arc Gouging and Cutting
    AWS C5.4 Recommended Practices for Stud Welding
    AWS C5.5 Recommended Practices for Gas Tungsten Arc Welding R(1994)
    AWS C5.6 Recommended Practices for Gas Metal Arc Welding R(1994)
    AWS C5.7 Recommended Practices for Electrogas Welding R(1994)
    AWS C5.10 Recommended Practices for Shielding Gases for Welding and Plasma Arc Cutting
    AWS C6.1 Recommended Practices for Friction Welding
    AWS C7.1 Recommended Practices for Electron Beam Welding
    AWS D1.1 Structural Welding Code - Steel
    AWS D1.2 Structural Welding Code Aluminum
    AWS D1.3 Structural Welding Code - Sheet Steel Second Edition
    AWS D1.4 Structural Welding Code - Reinforcing Steel
    AWS D1.5 Bridge Welding Code
    AWS D3.5 Guide for Steel Hull Welding
    AWS D3.6 Specification for Underwater Welding
    AWS D3.7 Guide for Aluminum Hull Welding
    AWS D8.5 Recommended Practices for Automotive Portable-Gun Resistance-Spot Welding; Supplement - 1969"
    AWS D8.7 Recommended Practices for Automotive Weld Quality-Resistance Spot Welding (SAE J 1188) R(1994)
    AWS D8.8 Specification for Automotive and Light Truck Components Weld Quality - Arc Welding SAE HS J1196
    AWS D8.9 Recommended Practices for Test Methods for Evaluating the Resistance Spot Welding Behavior of Automotive Sheet Steel Materials SAE D8.9
    AWS D9.1 Sheet Metal Welding Code
    AWS D10.4 Recommended Practices for Welding Austenitic Chromium-Nickel Stainless Steel Piping and Tubing R(1992)
    AWS D10.6 Recommended Practices for Gas Tungsten Arc Welding of Titanium Pipe and Tubing
    AWS D10.7 Recommended Practices for Gas Shielded Arc Welding of Aluminum and Aluminum Alloy Pipe; Errata R(1992)"
    AWS D10.8 Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and Tubing R(1992)
    AWS D10.10 Recommended Practices for Local Heating of Welds in Piping and Tubing
    AWS D10.11 Recommended Practices for Root Pass Welding of Pipe without Backing R(1992)
    AWS D10.12 Recommended Practices and Procedures for Welding Low Carbon Steel Pipe
    AWS D10.13 Recommended Practices for the Brazing of Copper Pipe and Tubing for Medical Gas Systems
    AWS D11.2 Guide for Welding Iron Castings
    AWS D14.1 Specification for Welding of Industrial and Mill Cranes and Other Material Handling Equipment R(1991)
    AWS D14.2 Specification for Metal Cutting Machine Tool Weldments
    AWS D14.4 Specification for Welded Joints in Machinery and Equipment R(1991)
    AWS D14.6 Specification for Welding of Rotating Elements of Equipment
    AWS F1.1 Method for Sampling Airborne Particulates Generated by Welding and Allied Processes
    AWS F1.2 Laboratory Method for Measuring Fume Generation Rates and Total Fume Emission of Welding and Allied Processes
    AWS F1.3 Sampling Strategy Guide for Evaluating Contaminants in the Welding Environment
    AWS F1.4 Methods for Analysis of Airborne Particulates Generated by Welding and Allied Processes
    AWS F1.5 Methods for Sampling and Analyzing Gases from Welding and Allied Processes
    AWS F2.1 Recommended Safe Practice for Electron Beam Welding and Cutting
    AWS F2.2 Lens Shade Selector
    AWS F3.1 Guide for Welding Fume Control
    AWS F4.1 Recommended Safe Practices for the Preparation for Welding and Cutting of Containers and Piping
    AWS F6.1 Method for Sound Level Measurement of Manual Arc Welding and Cutting Processes R(1989)
  3. Thank YOU for the great effort, but could you pls upload it in another web host, ifile or mihd since rapidshare are not working properly here..
    Thanx & Best Regards.
  5. Thank you; but the rapidshare links doesn't work!!! Could be possible to you re upload?
  6. Re: AWS great collection
    Can anyone reupload pls?
  7. Re: AWS great collection
    Can anyone reupload pls? i need AWS D10.12 Recommended Practices and Procedures for Welding Low Carbon Steel Pipe
    thanks in advance
  9. Re: AWS great collection
    Please updolad again
  10. Re: AWS great collection
    Please ...
  11. Re: AWS great collection
    Please any kind people for reupload...
  12. Re: AWS great collection
    Please reupload
    Please reupload.
  14. Re: AWS great collection
    can anyone upload these books?
  16. #12
    Sep 2011
    Nha Trang, Vietnam
    Hi BornToSin brother,
    Would you please re-upload these docs.
    Thanks you so much!
  1. Saying HI, and Thanks for all the Great Info
    By rftop in forum Free Zone
    Last Post: 07-10-2013, 07:28 PM
  2. Great international job in HS&E available
    By alexnysf in forum Safety And Environment
    Last Post: 08-02-2010, 03:45 AM
