Results 1 to 6 of 6
Thread: Instrumentation Design Studies
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    Cool Instrumentation Design Studies
    Ernest Doebelin, "Instrumentation Design Studies"
    CRC | 2010 | ISBN: 1439819483 | 725 pages | PDF | 24,5 MB
    Integrating physical modeling, mathematical analysis, and computer simulation, Instrumentation Design Studies explores a wide variety of specific and practical instrumentation design situations. The author uses MATLAB® and SIMULINK® for dynamic system simulation, Minitab® for statistical applications, and Mathcad for general engineering computations. Rather than consult the extensive manuals of these software packages, readers can access handy, sharply focused material in the appendices to assist in comprehension.
    After introducing the techniques behind the design of experiments (DOE), the book discusses several technologies for implementing vibration isolation, the design of a high-accuracy pressure transducer, and the use of cold-wire thermometers for measuring rapidly fluctuating fluid temperatures. It then focuses on a basic piezoelectric actuator that provides translational motions up to about 1mm full scale with nanometer resolution, before covering instruments used to measure the viscosity of liquids as well as two special classes of microphones (infrasonic and ultrasonic) and their important specialized applications. The book also presents statistical tools, such as hypothesis testing and confidence intervals, for experiments; the design and applications of thrust stands for measuring vector forces and torques; and the analysis and simulation of a shock calibrator. It concludes with a discussion of how shock testing machines can help reduce or prevent mechanical failures.
    Spanning system dynamics, measurement, and control, this book addresses the needs of practicing engineers working in instrumentation fields. It focuses on instruments for various applications, from geophysics to mechanical and aerospace engineering.
  3. Thanks
    Thanks !
  6. The link is not working, Please upload it again
    Thanks in advance
  7. other links:
  9. Dear Friends;
    Would you please upload it in ifile.it or rapidshare or 4shared?
    For me it would not possible to download from above links.
    B.R
  1. Chemical Process Design Computer-Aided Case Studies
    By Freeman in forum Petrochemical
    Last Post: 09-06-2009, 11:45 AM
  2. Replies: 1
    Last Post: 02-25-2009, 01:16 AM
