This ***** fixes some problems of Aspen HTFS+ 2006 as per the file inside.
good work
Thank u bro
Hello velayati. I have AspenONE 2006 and i am using HTFS+ for Design and rating of shell & tube heat exchangers. My problem is that when importing properties from HYSYS and runing the rating/design the program fail. The other error is that when importing condesation / evaporation cases from HYSYS. I was wondering if you this has been fixed by Aspen and if there is a ***** for HTFS+ 2006. If you have it or you know were i can find it it would help me a lot!!!
Thanks in advance!!! regards
Joaquin
the link is not complete, plz check it
hey, I can't run the TASC+, a message is popping after starting the TASC program.."Failed to access SLM license manager or no active SLM was found"..."problem checking out license for Tasc"
I tried to open the link provided by you, but an error is occurring that file can't be found.
Can you help me?
Plzzzz
Hi Guys,
Is there anyone can explain to me when characterising fluids with four main physical properties as we can do in HTRI. Appreciate respond from the team.
Anwar
