Thread: Lead Vinyl Sheets MSDS required urgently plz
  1. Lead Vinyl Sheets MSDS required urgently plz
    Does anyone have MSDS( Material Safety Data Sheet) for Lead Vinyl Sheets material?
    It would be very helpful if someone can provide me. Urgently needed please.
    can you be more specific? There is no such plastic sheet known as Lead Vinyl. Lead is a stabilizer used in PVC sheets. Your question lacks clarity.
  5. The Lead Vinyl Sheets are a flexible protective material available in a variety of lead equivalents for use wherever additional protection is required. It can be cut and shaped for many protective applications. It is 10% lighter in weight compared to that of lead rubber for the same lead equivalency. The sheets are sanitary and non-absorbing with smooth surfaces on both sides. The material is non-aging, therefore, it has an indefinite shelf life.
  1. Required urgently
    By nael in forum Safety And Environment
    Last Post: 02-21-2012, 03:46 AM
  2. urgently required
    By tausifahmad01 in forum Reservoir
    Last Post: 09-25-2011, 09:06 AM
  3. Lead Vinyl Sheets MSDS required please!
    By mohammed21 in forum Oil And Gas Production
    Last Post: 09-10-2010, 06:45 AM
  4. Lead Vinyl Sheets
    By mohammed21 in forum Mechanical Engineering
    Last Post: 09-09-2010, 04:24 AM
  5. Help required urgently...
    By syamantakdhar in forum Petroleum Refining
    Last Post: 11-18-2008, 03:48 AM
