Results 1 to 7 of 7
Thread: Hydrocarbon Data Systems software
  1. Hydrocarbon Data Systems software
    Dear friend
    while searching i found this page
    does any one have this software and *****
    HDS2000
    a development of Hydrocarbon Data Systems, Inc.
    The HDS LOG ANALYSIS PROGRAM was first conceived, developed and copyrighted in the mid 1980’s by HYDROCARBON DATA SYSTEMS, INC. of Houston, Texas. It started life as a basic interpretation application, which was designed to make the processing of multiple calculations easier for a well-site geologist. Over a very short period the program grew with the addition of more functionality and in 1985 a decision was made to release it as a commercial product. This first version, now called HDS, ran on an MS-DOS platform and soon developed into a very powerful and versatile tool with a considerable user base. In the early 90’s it became obvious that HDS had to move into a Windows environment in order to meet the power requirements of the users and to keep abreast of ever changing technology. The move to Windows proved to be a changing point for the company, as the Windows version of HDS attracted a greater number of users, including petrophysicists, educational establishments, governments and other sectors of the oil and gas industry. This continuing evolution of the HDS system has now resulted in their latest release, a very powerful and versatile interactive 32 Bit MS Windows application. The HDS user base has now increased to over 350 installations worldwide and the company has a comprehensive pro-active (and reactive) development program in place.
    Hydrocarbon Data Systems employs a small but dedicated team of specialists to further develop, enhance and support the HDS software. The team includes: programmers, geologists and a petrophysicist whose combined efforts continue to produce the most reliable and robust log analysis software on the market today.
    The original concept behind the HDS software was to make an easy-to-use but effective tool for geologists and engineers. Hydrocarbon Data Systems understood the needs of these individuals and as a result incorporated some very basic principals in their software design. These principals, which are still in effect today, are as follows:
    the ease in which log data is input into the program
    versatile data editing routines
    the flexibility and complexity of the calculations
    the variety of printout options to aid in the analysis and
    easy integration of HDS data with other software packages
    The HDS program addresses most of the major requirements of a petrophysical package, which are as follows:
    · File Management Utilities · Single and Multi-Well Analysis
    · Multiple Data Input Routines · Versatile Data Editing Routines
    · Flexible Cross Plot Routines · Complete Calculation Suite
    · Payzone Summaries · Comprehensive Log Plots
    · ASCII Data Output Files · Imperial or Metric Log Units
    · Complete Help Files
    In addition to the above HDS also has numerous other in-built functions and tools (which in some cases are quite unique to HDS) and which are described in brief on the following pages. Further information can also be supplied by Hydrocarbon Data Systems or their agents.
    PROGRAM FLOW
    The HDS program has been developed in a Windows environment and utilizes all the functionality of Windows to make the software easy to use and understand plus ensure that new users have the shortest possible learning curve. The screens are designed to be uncluttered and clear and the user is given the option to carry out either in-depth or simple quick look analysis through a point and click menu system.
    HDS functions are controlled and operated via Windows 32-bit drop-down menus or interactive icons, through the use of a mouse or cursor. The Main Menu controls the branching of the program and gives the user full access to all major program functions. Data is input into HDS through either digitized input, an ASCII file, a DLIS file or an LIS file and can be input as TVD (True Vertical Depth) or measured depth.
    WELL INFORMATION
    Well Description: This option lists identification data of the well being investigated. The fields in the Well Description are Path & File Name, Operator, Well & Field Name, Location, Legal Description, County, State, A.P.I Number, Wireline Company and the Processing Units of the file.
    Borehole Environment: The primary function of this option is to control the depths and the logging parameters for the log calculations. This section will store five log runs of data. Most environmental corrections will require input of the parameters from the log header.
    Directional Surveys: The program can accept up to 1000 directional surveys from a source such as a multishot. The inputs include measured Depth, Inclination Angle and Drift Angle/Azimuth. TVD and Total Rectangular Coordinates are computed instantly. Five computation methods are available including "Radius of Curvature". You may also initialize several thousand feet down the hole by setting the rectangular coordinates at a given depth. This function allows for an accurate Pay Count total using TVD rather than measured depth units.
    Formation Tops: This option will set user defined zones of interest under designated formation names. The formations can be used in various printouts and summary files and all multi-well options. The information is set graphically or spreadsheet. When the Paycount Summary Option is accessed in combination with Formation Tops, values such as Sw and Average Porosity are saved to disk in a format accessed by most commercially available database programs for mapping and reserve estimates.
    Other Information: Includes Perforation; Data Drill Stem Test (DST); Repeat Formation Test (RFT); Sidewall Cores. All information is set from the visual (graphical) or spreadsheet mode.
    LOG DATA Input/Edit
    Data Editing: There is a number of editing tools supplied with the software that are accessible in spreadsheet or graphical (visual) formats. The Data Editor Menu accesses the following data manipulation routines:
    Interactive Depth ShiftBaseline Shift Units Conversion Curve SmoothingDespike Graphical *****ing Normalize Data Rescale CurvesMath Toolkit Splice
    The data is saved as a new version of the curve. The original data or the edit data can be referenced, processed or reviewed in most any option. A note is created and posted to the Process History table. The note will include the procedure and the curve name of any new data.
    The Depth Shifting option will move the log data on a linear shift or stretch/squeeze mode. The log curves and the zones to be shifted are user defined or you can use the auto-correlation mode where the program performs a coefficient of the correlation.
    Statistics: A statistical review of the log data can be viewed and/or printed in both text and Histogram formats. The data can be normalized using a multi-well model.
    DLIS & LIS Input/Output: This function is performed using a third party piece of software called EZTools, which was developed and is licensed by Oilware, Inc. in conjunction with HDS. EZLIS and EZDLIS feature direct conversion to HDS Data Format and supports DLIS/LIS tape or disk files. The software will read 800 and 1600 bpi data and most 9 track tape drives and converts directly to the HDS format or an ASCII data format. A Catamount, Overland, AKS or IDT controller card is required.
    EZLIS is licensed and sold separately to the HDS software, and may require a service call for installation.
    ASCII File Reader: This program will read most ASCII data formats including hundreds of interpretations of the LAS format. It is the quickest method of creating an HDS data file. You can view the entire ASCII file before the conversion process commences and the types of data and the zones of interest for the HDS file can be user defined. When the HDS file is created the ASCII source file will remain in its original data structure.
    Digitize Log Input: The Log Digitizing module supports most commercially available tablets. The data input is in a point mode or in a stream mode for extremely fast input of log data. The log data can be entered in intervals varying from 0.1 - 10 in units of feet or meters. When entering data via digitizing tablet, a 200-foot section of log on a 5-inch scale with 7 data curves can be digitized in 5 to 15 minutes depending on your individual speed.
    The information that is input with the digitizing tablet is sorted numerically and meshed with the other log data on file. If you digitize over an existing curve or point, the program will automatically save the latest information. All data entered from the digitizing mode can be edited.
    All track origins and scales are user defined in the setup. This eliminates errors in stretched or reproduced logs. Both linear and logarithmic scales are available before digitizing.
    The input data is all depth related and the program accepts the curve information in any from any wirieline data tool. This includes but is not limited to:
    . Gamma Ray . Neutron Porosity . Delta t (Dt) . Spectral Gamma Ray . Density Porosity
    . Sonic Porosity . EPT – Propagation . Spontaneous Potential . Bulk Density
    . Caliper (Holesize Data) . Production Log Data . Resistivity Data . Bulk Density Correction
    . Tension . Pulse Neutron (TDT) . Conductivity . Photo Electric (Pe) . Micro Logs
    . User Defined Data . NML
    Core Data Input: This option will read most ASCII core data files or the data can be input via keyboard. All editing functions offered in the Log Data Editor are available with this option. Core data can be used in calculations and cross plots and it is available for graphical output. The following is a list of acceptable data:
    . Length . Oil % (Pore Volume) . Core Description . Grain Density
    . Gamma Ray . Water % (Pore Volume) . Production Code . Core Porosity
    . Probable Production . K Permeability - Max & Min . Description
    Environmental Corrections are available for most logging company charts. The visual interface displays the input curve, the output curve and the correction factor. The corrections are available for:
    . Gamma Ray . Density . Neutron - Open Hole
    . Neutron - Cased Hole . Invasion . Resistivity
    . Induction Standoff . Rxo Mudcake
    LOG CALCULATIONS
    All processing can be accomplished in visual (graphical) or spreadsheet mode. The following is a list of the major calculations and options performed through user defined specifications.
    Shale / Clay Volume
    . Gamma Ray Index - Linear . Spontaneous Potential . Neutron
    . Gamma Ray - Non Linear 10 models . Neutron-Sonic . Density-Neutron (Matrix or Ratio)
    . Spectral GR . Multi-Clay Method . Sonic Dispersed Shale Model
    Neutron Log Options
    . Neutron – 15 Charts . User Defined Matrix . Effective Porosity Corrections
    Density Log Options
    . RhoB via Density Porosity . Effective Porosity . Variable Pore Fluid Density
    . Porosity via RhoB . User Defined Matrix
    Density Log Options
    Neutron – Density Options
    . Straight Average . Sum of Squares . Weighted Average . Gas Corrected
    Sonic Log Options
    . Raymer/Hunt or Wyllie . Hydrocarbon Corr. . Shale - Dispersed or Laminated
    . Variable Matrix and Fluid . Compaction Corr.
    Cross Plot Porosity – Multiple Matrix Solutions for
    . Neutron – Density . Neutron - Sonic . Density – Sonic
    Water Resistivity
    . Rw corrected for temperature . Rw via Salinity . Resistivity of Free Water (Rwf)
    . Rw via SP method . Rw via Rwa method . Resistivity of Bound Water (Rwb)
    . Rw via Pickett Plot . Rw via Hingle Plot . Resistivity of Mixed Water (Rwm)
    Resistivity
    . Rt (Induction Log or Laterolog) . Flushed Zone Resistivity . Laterolog - Seq. or Sim.
    . Exponential Sxo
    Water Saturation Models
    . Archie . Fertl Method . Dual Water Analysis (2 Methods)
    . Simandoux (3 Methods) . Indonesian . Waxman-Smits (3 Methods)
    . Shell Equation . Pulsed Neutron . User Defined Formation Factor
    Permeability
    . Coates & Dumanoir . Wyllie & Rose . User Defined
    Lithology Determination
    . Cross Plot Porosity . Sand/Shale Environment . Rho Matrix Apparent
    . Neutron-Sonic . P.E. – 3-4 Mineral Model . M - N Plot
    . Dt Matrix Apparent
    VB Scripting – User-Defined Equations
    . Full Screen Edit . If-Then-Else Logic . Run Simultaneous Equations
    True Vertical Depth
    . Radius of Curvature Method . Input All Surveys or Initialize the Rectangular Coordinates for first depth
    Miscellaneous Equations
    . Bulk Volume Water (BVW) . Movable Oil Saturation (MOS) . Movable Hydrocarbon Index (Sw/Sxo)
    . Water Saturation Ratio (Swr) . Residual Oil Saturation (ROS) . Badhole Logic
    . Irreducible Water Saturation (Swi) . Hydrocarbon Pore Volume (HPV) . Coal Logic
    As many as twenty (20) calculation templates can be built and saved to meet your general needs as new files are created. The option, Master Default File, will save a set of calculation options and parameters in a calculation template. This is particularly useful when working with several wells in a particular field or trend. Any formula or parameter set from a calculation template can be overwritten in the Calculation Options.
    Tweak (Interactive Parameter Setup): is a new routine for interactively setting most of the petrophysical parameters for a given zone. The results of any parameter change are instantly shown on the screen. The menus for each parameter group includes a cross plot (representing standard chart books), input boxes and choice lists, numeric slider controls, and log plots with the input and processed curves. The parameters can be set with the numeric sliders, entering a value in the input boxes, clicking on the log plots, clicking on the cross plots, and in some cases clicking on a histogram.
    In addition to the user selections, an automatic parameter selection (AutoSel) can be called. This option will determine parameters for a reservoir based on geo-statistics. The analytical menus include multiple shale/clay options, all single porosity setup, the full range of cross plot porosity options, multiple water saturation models with associated parameters and lithology determination. The water saturation menu gives the user the choice of toggling through all of the possible porosities, single and multiple shales, formation factors, and saturation equations with immediate review.
    The program will perform the analysis on a zone by zone basis which is defined by the user. All parameters set in the module are moved forward to other sections of the software for end product processing. There are petrophysical tips interlaced through the program to assist the analyst.
    CROSS PLOT options include Hingle Cross Plots, Pickett Cross-Plots, M-N Cross Plots, Porosity Lithology Cross-Plots and User Defined Cross-Plots. In total there are 23 preset cross plots plus an unlimited number of user defined plots. The cross plots feature a user defined curve fitting and data identification of depth in reference to a log curve. Multi-well cross plots and log plot options are now available as new feature in this section.
    The User Defined Cross Plots can access any three curves for X, Y and Z-axis. All scales are user selectable. The graphs can be log/log, log/linear or linear/linear. This option has curve fit math routines. On screen editing is offered on all cross plots.
    MULTI-WELL OPTIONS
    The multi-well options will work with a group of well files from a user-defined project. The routines are:
    . Calculations . Pay Summaries . Log Plots . Crossplots . Cross Sections
    Once a well list is built, the data can be run through any number of routines and generate your desired output. The pay summary output can include multiple well files over set formations all written to one file (ASCII or Excel). This file can easily be moved to any mapping or reserves package. The cross section plot includes (x) number of wells that can be tied structurally or stratigraphically. The crossplot options include a curve normalizing routine.
    PRINTOUT OPTIONS
    The Printout options consist of Tabular Form, Payzone Averaging, Formation Averaging, and Log Plots. All printouts can be viewed on the screen, printed on the selected printer or saved as a disk file (ASCII/BMP). The proceeding pages include some of the output options included in this package.
    Log Plot options produce a user-defined image of input data, process data (calculated) and/or core data. All curves, tracks and scales are set by the user or a user defined template. The complete Windows palette of colors and patterns is available. The output of the plot can be printed on most printers and plotters.
    Other primary features are: up to 8 tracks plus the depth track on any plot; unlimited curves (input/calculated/core) per track; all curves are user defined; 8 selections for width of the track; user-defined vertical scale options; line type selection (7 styles); perforation markers; pay zone markers; formation labels; annotation of text; DST’s; RFT’s; core markers; log foot notes; print as measured depth, SubSea or TVD; on screen editing; all plots saved as templates for future use with other well log files.
    Tabular Form will print all log data and all calculated data. There are user-defined settings for all output curves and the depth ranges. A summary of all calculation options is available with all text printouts.
    Payzone Summaries will apply user-defined cutoffs from any calculation or input data. One or any combination of cutoffs can be used in this option. The printout will display the total hydrocarbon feet and the average values from the data that meets the designated criteria. This printout will access the whole file or user defined formations. If formations are used each formation is summarized and printed separately.
    HDS -- SamplePay Summary Report
    OPERATOR: HDS O&G
    WELL NAME: Sample Log Date: 09-27-2001
    COUNTY: Liberty Time: 12:23
    STATE: Texas A.P.I. NUMBER: 12345-5678
    Total Feet Vsh Porosity Sw Bvw Bvh
    WB - 1 Sand - Gas (4437.0 – 4480.0)
    23.5000 11.485 24.500 28.345 6.842 4.150
    WB - 3 Sand - Gas (4613.5 – 4754.0)
    111.5000 5.184 24.736 12.293 2.948 24.294
    WB - 4 Sand - Oil (4807.5 – 4952.0)
    114.5000 3.425 26.104 21.323 5.435 23.666
    Final Totals -- All Formations
    249.5000 4.970 25.342 17.949 4.456 52.110
    Current Pay Zone Cutoff Filters & Calculation Options
    Vsh 40.00 – Max.; Porosity 18.00 – Min.; Sw 50.00 – Max.
    (Vsh) -- Shale Volume
    VShale Model: Gamma Ray – Larinov – Teriary
    Gamma Max. - Min: 92.4, 8.22
    (PhiD) -- Density Porosity
    Density Matrix: 2.65
    Pore Fluid Density: 1.00
    Calc. Effective Density: Yes
    Effective Density: 18.00
    (PhiN) -- Neutron Porosity
    Neutron Log Type: HALLIBURTON DSNII
    Neutron Matrix: Sandstone
    Calc. Effective Neutron: Yes
    Effective Neutron: 44.6281
    (PhiND) -- Neutron-Density Porosity
    Neutron-Density Model: Gas Corrected Density
    Hydrocarbon Density: 0.34
    Core Corr. 1 - 200%: 100.00
    (Rt) -- True Resistivity
    Rt Source: RILD
    (Rw) -- Water Resistivity
    Known Rw: 0.034 @ 133.97F
    Temperature Corr.: Yes
    (Sw) -- Water Saturation
    Water Saturation Model: Archie Eq.
    Tortuosity (A): 0.62
    Cementation Exponent (M): 2.06
    Saturation Exponent (N): 1.97
    Porosity Source for Sw: PhiND
    MAJOR PROGRAM FUNCTIONS
    · Flexible Management of all Data Curves and Data Sets
    · Robust Data Loading Options
    · Complete Set of Data Editing Tools
    · Zonal Interpretation.
    · The user may set any variable interactively on log or spreadsheet.
    · All variables have default values if they are not set by the user.
    · All Models display required support information
    · All Options are saved with Calculated Data for reuse.
    · Complex Lithology Determination.
    · Interactive and Full Featured Cross Plots
    · Statistics
    · Batch File Processing.
    Hydrocarbon Data Systems have a number of projects underway to further improve and extend the capabilities of HDS. Some of these projects are listed below and most have been recommended by the user base.
    ¨Synthetic Seismogram ¨Active X Interface
    ¨True Stratigraphic Thickness ¨Volumetrics
    ¨True Vertical Thickness ¨NMR Interpretation
    ¨Production Log Analysis ¨Base Map Interface
    Hydrocarbon Data Systems also offer consulting services in petrophysical applications, training, digitizing and tape conversion services.
    To download the above information in PDF format, right click here and save the file.
    here's the link to this page
    ******** needed
  5. pls if you have the setup can u pls upload it. we will find somebody that will ----- it.
  6. Hi all
    If any body have this software with its ..... plz upload it
    thnx
    ******** please
    Muhammad Khurram
  9. Please share the setup file then search for somebody to ......... it
  10. Re: Hydrocarbon Data Systems software
  1. Replies: 0
    Last Post: 02-16-2010, 05:24 PM
  2. Replies: 0
    Last Post: 02-16-2010, 05:23 PM
  3. Replies: 0
    Last Post: 02-16-2010, 05:22 PM
