Results 1 to 6 of 6
Thread: PHAST Risk 6.54 Help
  1. PHAST Risk 6.54 Help
    Hello.
    Hello.
    I am working on a project where in I need to model a Ground Flare Consequence and Risk Analysis using DNV PHAST Risk 6.54. So can somebody help me with these following questions:
    1. Which Scenario to be considered in PHAST ? like Relief Valve, Leak or..... ?
    2. What are the kind of the data I need to run this case ? and
    3. How to come up with Event Frequency in my Risk Analysis ?
    4. If you have any go by's or any material related to above which you think might help, please share it with me.
    NKR
  3. Hello
    I think the user defined model can be used
    yes and it jet fire effect
  6. the shape of the fale can be assimilated to a cheminy.
    If you have a special question about flare, i 'll try to help you
    Quote Originally Posted by evolutionb View Post
    could u please send on this forum or to my email vivek.68@gmail.com
    a phast file on vertical flare gas dispersion under flame out condition
    for gas misture containing 1000ppm H2S . other consition as below
    Gas flow rate 0.5 MMSCMD , flare height 30m
  9. For high pressure flare (sonic of supersonic) usual leak model can be used. User defined model also good, but you need to know all discharge parameters.
  1. Need Help for Risk Analysis with DNV's Phast Risk Software
    By Sanjay kumar G R in forum Safety And Environment
    Last Post: 06-16-2014, 10:23 AM
  2. PHAST RISK software
    By TaShi in forum Safety And Environment
    Last Post: 01-21-2014, 09:55 AM
  3. Article: PHAST Risk 6.54 Help
    By nkr3114568 in forum Home Articles
    Last Post: 12-09-2012, 10:48 PM
  4. Article: Need Help for Risk Analysis with DNV's Phast Risk Software
    By Sanjay kumar G R in forum Home Articles
    Last Post: 04-10-2012, 07:35 AM
