DEAR ALL
I need the standards test procedure for Drilling Fluids Materials especially for PAC’S
Appreciate your help
DEAR ALL
Is this what you want?
API RP 13B-1 4th Ed. Mar. 2009 - Recommended Practice for Field Testing Water-based Drilling Fluids - ISO 10414-1;2008.pdf
Thank you very much Nabilia
this file is also useful for me
Actually what I need exactly is API-13A Specification for Drilling Fluids Materials, which is the standard procedure to test the quality of drilling fluid additives
but if you have any of API-13, I will be so grateful for you :-)
Here you go...
API Specification 13A 17th Ed. Nov. 2006 w:Oct. 2008 Errata - Specification for Drilling-Fluid Materials - ISO 13500;2006.pdf
thank you very much Nabilia
appreciate your help
Please if you have a newr version from the same standard please share, because what i looking for is the stand. test for low-viscosity polyanionic cellulose (PAC-LV), high-viscosity polyanionic cellulose (PAC-HV), beacuse the older versions does not contain this stand test.
i am soooo grateful for your kind help
regards
Sorry I don't have the latest...
People help find....
Spec 13A/ISO 13500:2009␣␣ Specification for Drilling Fluid Materials Petroleum and natural gas industries—Drilling Fluids—Specifications and testing Covers physical properties and test procedures for materials manufactured for use in oil- and gas-well drilling fluids. The materials covered are barite, haematite, bentonite, nontreated bentonite, OCMA-grade bentonite, attapulgite, sepiolite, technical-grade low-viscosity carboxymethylcellulose (CMC LVT), technical-grade high-viscosity carboxymethylcellulose (CMC- HVT), starch, low-viscosity polyanionic cellulose (PAC-LV), high-viscosity polyanionic cellulose (PAC-HV), drilling-grade Xanthan gum, and barite 4,1. This Standard is intended for the use of manufacturers of named products. This edition of API Spec 13A is the identical national adoption of ISO 13500, Petroleum and natural gas industries—Drilling Fluids— Specifications and testing, and includes the addition of an API Monogram Annex. Pages: 109 18th Edition | February 2010| Effective Date: August 1, 2010
