Folks,
Could you please answer this question: How can i operate Pipesim2003 under windows vista operating system? Any tricky solution? Or what versions of Pipesim can be operated under vista? Please Help!!!!!!!!!!!![]()
Cheers
Folks,
Cheers
If so many softwares are available for download then naturally (and perhaps logically as well) people primarily focus on downloading and collecting more and more softwares instead of operating them. Generally if someone is doing some project then he / she uses only the relevant one. Otherwise, most of the softwares are not installed or if installed then not used atleast for professional growth (i.e. properly following some course or tutorial) May be everyone is very busy so limited time available can only be given for download. This is not only my personal opinion but also numerously observed and discussed with various giant downloaders.
Regarding your query. Generally system requirements are mentioned in small text file. Please check suc files in the folder. You can also check system requirements at the official site of pipesim. Just fill the following form:
Also check the following link. It is reference guide of Pipesim.
[hide]http://prosys.korea.ac.kr/~tclee/hysys/manual/Pipesim/RefGuid.pdf[/hide]
Have a nice day
thank you
Thanx
Processor, Thank you very much for your long answer and maybe tiring as well. On the other hand, it was allright to convey to me only last paragraph
Thanks&Regards
im using pipesim 2003 under windows vista without problems
Thank You
Thank you very much
JuanCat,
Thanks first of all. I installed and it works but it gives a warning massage for update. If you say no, you can continue to use pipesim. If yes, it gives update error due to wrong script error.I dont want to see this warning message. Do you have a problem like that i mean warning message? I need to know what to do not to see this message at the beginning?
thank you
Thank you
very thank you sir
