Dea ALL
ffA provide world leading 3D Seismic Analysis Software and Services to the oil and gas industry.
ffA software extracts geological features from 3D seismic data, objectively and more rapidly than with conventional techniques to help geoscientists and engineers to make better decisions with higher confidence, in less time.
The result - significant gains in productivity and risk reduction at all stages of the E&P cycle including seismic interpretation, prospect generation, target definition and well planning.
SVI Pro™ is a standalone Windows 3D seismic image analysis and visualisation application.
SEA 3D Pro™ is is a Linux application with the option for direct integration with GeoProbe™.
Both applications have a flexible licensing system with access to Core Functionality and Optional Modules .
16 and 32 bit data can be processed and visualised with unlimited volume size.
SEA 3D Pro and SVI Pro: The Core functionality
The Core enables volume attribute analysis for rapid data screening
and delineation of geological features such as faults or stratigraphic
geobodies. The results can easily be integrated into any seismic
interpretation, 3D modelling or well planning workflows.
Affordable 3D seismic analysis with no quality compromise
The Core Application includes:
Batch Processor
Multi Volume Opacity Blends
Advanced Colour Blends
GPU based accelerated processing
Noise Reduction: ffA’s full range of advanced structurally oriented algorithms
Comprehensive Set of Structural, Stratigraphic and Edge Attributes: multiple algorithms available for optimal results independent of data quality
Fault Imaging Workflows: the best fault imaging toolset on the market
Stratigraphic Workflows: including Carbonate and Clastic feature analysis
Single and multi attribute computation
Single and multi attribute Geobody delineation
Multi attribute volumetric Colour Blend visualization
Geobody manipulation
Multi-volume Mathematic Calculator
Full Resolution Processing of 8, 16 and 32 bit data
Large Volume Processing and Visualization on Standard Desktop and Laptop Hardware
High Fidelity 2D/3D Visualization
You can complement the Core functionality with optional Modules to tailor-make your 3D seismic analysis application.
ffA workflows have been proven worldwide in clastic and carbonate environments offshore and onshore.
"ffA’s Dip and Azimuth attribute volumes, combined with a continuous Top Rotliegendes seismic surface, significantly facilitated mapping of subtle lineal elements known to affect fluid compartmentalisation in this part of the southern North Sea gas province. In addition, ellipsoidal seismic artefacts related to the occurrence of halite pods in the lowermost Zechstein overburden became apparent."
So please if any one have this software please share it here in this forum.
asabdu
