Hello Brothers,
Sharing with you a simple utility which helps you identify NDT requirements for process piping as per ASME B31.3.
The salient features are:
1. It specifically mentions all the requirements of all type of NDTs as per ASME B31.3 Process Piping Code.
2. It takes simple inputs from the user about fluid type and service conditions.
3. Transforms the inputs into the fluid category itself.
4. All four type of fluid services as per ASME B31.3 have been included.
5. Severe cyclic conditions and elevated temperature services have also been mentioned separately.
6. It strictly specifies requirements of NDT for process piping only as per ASME B31.3 and not for pressure vessels or any other piping code.
7. Detailed hints and tips have also been included. Click "more" on main window to see.
8. As the code defines the minimum requirements so piping designer / owner may make them more stringent.
9. Easy and simple to use.
10. It's a beta version and bugs may come up which will be resolved as and when prompted.
Download:[link Point to another website Only the registered members can access]
Hope you would like the program.
Ashfaq
