The interviewer will surely ask you why you wanna be a Field Engineer ?
(I applied for FE position, but end up with Drilling Engineer position)
You have to be sure that you know exactly what's FE do as well as work environment in the field.
After you answer, they will know your attitude about this job. they will
tell you the disadvantages of this job such as hard work, very high pressure, tough environment, no free time, no time for friends and family, etc.
Then, they will ask you that you can withstand this or not.
They'll also emphasize asking about your weak points for putting high pressure on you.
Most of your answer will be infered in a negative way.
Personally, I think this is an important part. If you showed them that you are good in handle pressure, you'd be selected.
just be yourself, try to be calm and patient.
Best of luck
