Results 1 to 10 of 10
Thread: Crude Assay Library
    Crude Assay Library
    Does anyone have access to a database/library of crude assays from around the world?
    I'd really appreciate if you could post a link.
    Hi Dear Friend.
    I Have A Crude Manager Software (spiral Company). its Library has a Many Crude Assay Data from around the world. Which assay do you need.
    Hi, thanks for replying
    I'm working on a correlation between certain properties reported in crude assays, and so i basically need as much assay data as i can get my hands on. The only condition is that i need assays of heavy crudes (i.e. the asphaltenic (heptane insoluble) content should be larger then 5% by weight).
    Any no. of such assays you could upload would be tremendously helpful.
  6. hi,dsp151,could u plz share your spiral crude manager? thank you very much
  7. i need an assay data for oilfields of kazakhstan,especially Kashagan oilfield,if possible
    email: p_paren_1@mail.ru
    Re: Crude Assay Library
    Hi dear friend dsp151
    please share crude assay manager spiral soft ,thanks in advance
  10. Re: Crude Assay Library
    My friend, database/library of crude assays around the world has been included in HYSYS 8.0 and 8.2 you can get from HYSYS´s library.
    Hello my friend Roberdani12 how to access this library in hysys?????????? please help thanks in advance
  12. Re: Crude Assay Library
    Petroleum assay>>add>>select sources>> specified>>fluid package>>basis-1>>import form>>>assay library. Then select the assay that you need.
    before the process described above, you must to add a hypotetical component>>> generate Hypos
    thanks i will try and tell you if any problem
  1. Crude Assay
    By jordanlutherbasawil in forum Petroleum Refining
    Last Post: 07-05-2013, 06:25 PM
  2. Request for Crude Oil Assay
    By juice34 in forum Petroleum Refining
    Last Post: 07-06-2012, 06:19 AM
  3. Crude Assay Library
    By shubh in forum Petroleum Refining
    Last Post: 07-12-2011, 10:44 AM
  4. Crude assay
    By ashoktechi80 in forum Petroleum Refining
    Last Post: 11-03-2008, 10:17 AM
