Thread: Max Weigh a Beam take?
  1. Max Weigh a Beam take?
    hi Friends,
    I have an existing beam that I would like to know how much weight it can accommodate, Im not sure how to calculate this can anyone assist
    the beam is simply supported type, with two lugs on the edges(100mm inside). this beam also has 6 x 20mm diameter holes on each end/edge
    the dimensions of the beams are as follows:
    255mmx 255mm x 14mm thick
    lenght of beam is 6100mm
    Jul 2008
    malaysia
    Blog Entries
    2
    Quote Originally Posted by Jazz79 View Post
    hi Friends,
    Dear Friends,
    First thing, if you an engineer you will ask the application / what this beam is used for...is it for
    1. Support - ( Roof trusses / Pillar / etc
    2. Lifting application. - (spreader beam)
    Each have different kinds of design calculation and you can refer many books... (u can also find it on this forum).
    For me, I usually used the simple beam deflection calc since the Section moment of inertia of the required beam is also listed if you have standard size of Struc steel used...
    - the term Z = I/y is widely used and will show the result of required strength that you required.
    the useful link -
    [link Point to another website Only the registered members can access] PLEASE EMAIL TO ME I WILL SENT SOME USEFUL E-BOOK esp on roar'k formula at namasral@yahoo.com
    3.
  1. Help to get Beam Lift Handbook
    By CJROJAS in forum Oil And Gas Production
    Last Post: 01-14-2017, 12:03 PM
  2. Monorail Beam Analysis
    By ashokraj84 in forum Mechanical Engineering
    Last Post: 01-29-2014, 04:17 PM
  3. ES Beam Tool
    By bangash sn in forum Mechanical Engineering
    Last Post: 05-21-2012, 09:48 AM
  4. how to calculate I-BEAM
    By javad64 in forum Engineering Spreadsheets & Presentations
    Last Post: 06-07-2010, 06:36 AM
  5. how to calculate I-BEAM
    By javad64 in forum Mechanical Engineering
