Thread: Level Gauge Installation
    Smile Level Gauge Installation
    Hi guys,
    I have to install a level gauge on a separator, i suggested to insert a bleed ring then take the pickage.
    The problem is where can i isolate the level gauge before the bleed ring or after.
    I will be very happy if you give me the good answer.
    Thanks in advance.
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    It is batter to install bleed ring after isolation valve, it will be usefull to drain Level gauge for maintenance purpose, no use before installing Isolation valve, definately you r not interested in draining process.
    But problem is that, if u r taking tapping from piping through bleed ring for level gauge then there is no choice for u, u have to put isolation valve at the outlet of bleed ring only. which i can not make from your requirement.
    go to link
    Many Thanks...
  1. Maximum Length of Stand-Pipe (bridle) for installation of multi level instruments
    By saiedmehdipour in forum Instrumentation & Control
    Last Post: 12-17-2010, 06:25 AM
  2. Article: OS&D Level Gauge. Need your help
    By nautel in forum Home Articles
    Last Post: 09-05-2010, 11:10 PM
  3. OS&D Level Gauge. Need your help
    By nautel in forum Safety And Environment
    Last Post: 09-03-2010, 08:29 AM
  4. OS&D Level Gauge. Need your help
    By nautel in forum Instrumentation & Control
    Last Post: 09-03-2010, 06:41 AM
