Thread: mudmat and suction pile
  1. mudmat and suction pile
    The foundation of a subsea structure,such as manifold and PLET/PLEM, can be either the mudmat or suction pile.
    If there is already a suction pile, does it need a mudmat?
    I think a suction pile is enough to prevent a subsea structure from sliding or sinking!
    In a word, does a suction pile and a mudmat exist at the same time?
    Any body tells me, thanks in advance~
    Subsea manifold can be either designed with a mudmat or suction pile, generally according to the conditions of the soils. PLET/PLEM is mostly desinged with a mudmat. I've not seen any PLET with a suction pile on bottom of it. Suction pile is utilized for mooring of PLET subsea unless a 1st end PLET installation method is used.
  5. Quote Originally Posted by Abolo View Post
    Thank you very much!
    One more question, what's the mooring of PLET?
    When a pipeline is initiated from a pipelay vessel, a PLET (Pipeline End Termination) sled/structure with the pipeline is carefully lowered towards the seabed from a lay vessel and attached to the suction pile with a cable. This holds the pipeline back while the vessel continues laying the pipeline.
  1. Jack up Rig Leg, pile Penetration Analyzing Software
    By arun25hyd in forum Civil & Structural Engineering
    Last Post: 06-14-2015, 11:33 AM
  2. Pile stabbing guide design
    By mikesteel in forum Civil & Structural Engineering
    Last Post: 07-07-2014, 01:14 PM
  3. Pile Design and Construction Practice 4th Ed. Tomlinson 1994
    By Nabilia in forum Civil & Structural Engineering
    Last Post: 05-22-2013, 10:50 AM
