Thread: Article: Valve Trim Material
    You can view the page at
  3. Dear Hari,
    11-13% Cr steel & ASTM A105 + Stellite are not same 11-13% Cr steel trim is SS where as ASTM A105 + Stellite is CS , so SS is better than CS. I hope this will clear your doubt.
    Rahul
    Stellite valve trim is very commonly used to resist wear as it is very hard containing chromium, cobalt, tungsten, molybdenum. Principally stellite is an alloy of cobalt and chromium in which Cr is above 25% normally.
    What I think is stellite valve trim is better than 11-13% Cr material (normal F6 as hard F6 would be more harder due to nitriding) if stelliting has been done properly by the manufacturer. And I am saying this on the basis of hardness as normal Stellite 6 has a hardness of 350 HB as compared to F6 having 250 HB (without case hardening / nitriding).
    You may confirm it from the supplier also regarding long term applications with stelliting on CS.
    Ashfaq Anwer
  1. Valve and Piping Presentation Material
    Last Post: 09-05-2012, 04:55 PM
  2. Replies: 1
    Last Post: 07-03-2011, 08:38 PM
  3. question about material of valve
    By javad64 in forum Pipeline And Fluid Flow
    Last Post: 05-07-2011, 07:21 AM
  4. Article: Valve Seat
    By Mohd Zurairi Abd Ghani in forum Home Articles
    Last Post: 04-29-2011, 09:55 PM
  5. Valve Trim Material
    By hakr5 in forum Materials Science &Corrosion
    Last Post: 07-01-2010, 11:33 PM
