Pirson in Oil Reservoir Engineering proposed correlations for relative permeability estimation in shaly rocks. Does it means we can use this correlation where NTG < 1 ??
Bilal Amjad
no we can't
Kindly tell in detail..
(1) Just because a reservoir has a NTG of less than one, does NOT make it a 'shaly' reservoir
(2) Not all shaly reservoirs will follow that correlation
true
thanks.
I have also concerned Corey Functions for rel perm in oil water system, but cnfused about the corey exponent values,
have any idea about that?
(for reference visit[link Point to another website Only the registered members can access]
Corey exponents simply control the degree of curvature of the curves
Co and Cw = 1 will yield double straight line relationship
Exponents greater than 1 will tend to pull the curves down (retarding flow at adverse saturations), while less than 1 will bend the curves up. The curvature (up/down) and degree can be significantly affected by wettability, layering and block size to name a few.
vinomarky
i have search a lot of literature but not find about these exponents, can you give some reference/literature?
