IEEE Std 1050-2004 IEEE Guide for Instrumentation and Control Equipment Grounding in Generating Stations2005
Thanks.
Many Thanks....
Special Thnx.
thanks and keep uploading
IEEE Recommended Practice for Powering and Grounding Sensitive Electronic Equipment (IEEE std 1100-1992)
enjoy
Control System Power and Grounding Better Practice
Control system power and grounding is possibly the single most important element to ensure a control system doesn't experience unidentified "gremlins" throughout its life. The topic is appropriate to every control system domain, including programmable logic controllers, process control systems, robotics, vision systems, etc. Power and grounding is recognized by a major industry standards organization, ISA, in ongoing standards efforts.
Control Engineering and several power and grounding experts have developed this control system power and grounding resource. When used in conjunction with control system manufacturer installation documentation, users can expect robust, reliable control system installation; one that remains free of "phantom" problems caused by power and grounding glitches.
- Provides clarity for manufacturer's obscure system documentation
- The only single source control system power and grounding guide available.
- Details how to significantly improve reliability in control systems, saving valuable time and money.
# Publisher: Newnes
# Number Of Pages: 128
# Publication Date: 2004-02-23
# ISBN-10 / ASIN: 0750678267
# ISBN-13 / EAN: 9780750678261
Thanks !
how to calculate eathing requirement cable & earth pit requirements
Hi Sanjeev, if u r in india then my IS code will help u directly or just go through it it will certainly help you.
AS per Is minimum cable to earth pit shall be of 16mm, see table 7 in section 12 . Go to section 12 of IS 3043, for size of conducter and sizing of cable size.
current carrying capacity shall decide the branch earthing cables or main earthing cables size (based on your source of power to panel, which in turn goes to earth pit when fault occurs)
Hope you like this, comments from all users are welcome for discussions, i do not ahve BS /IEC/UL/IEEE code details about the Same.
Waiting for some to share
yes I am from India
do u have design formula & methods for same?
