Results 1 to 5 of 5
Thread: woodward 2301D speed and load sharing controller
    does any one here know how to set up communication link between the pc and the controller? using the free software from woodward.
  3. Have u tied with null modem cable using watch window? u need a cross cable mentioned on page 27 of tech manual 26247.
    Rehmat
    yes i have built the null modem but seems i cant set the baud rate right
  6. Dear
    Default baud rate is 38400, You can change the baude rate in network options window.
    Kind Regards,
    Rehmat
  7. Re: woodward 2301D speed and load sharing controller
    thanks i can now establish communication, this controller cpu status led flashes continously when ever the unit was shutdown, we have to take off power from the panel then allow the controller boot to stop the flashing led before we can re start what could be the problem. thanks
  1. can anyone sharing API 6L ,best regards
    By wlf7749 in forum Materials Science &Corrosion
    Last Post: 02-22-2014, 10:31 AM
  2. restraint nozzle load &#62; allowable nozzle load
    By aankhaerudin in forum Mechanical Engineering
    Last Post: 09-27-2011, 05:24 AM
  3. Sharing API 537
    By liewnh in forum Pipeline And Fluid Flow
    Last Post: 09-12-2010, 10:42 AM
  4. Sustained Load condition vs Installed Load condition
    By faisal99 in forum Pipeline And Fluid Flow
    Last Post: 08-17-2010, 11:37 AM
