Hi,
here are some[link Point to another website Only the registered members can access]
1. What is a characteristic of the Memory File System (MemFS)?
A. It supports /tmp and /var/tmp to be used as a MemFS.
B. It swaps data to swap space when the system is under memory pressure.
C. It uses disk devices to store compressed data.
D. Data in MemFS remain persistent after unmounts and reboots.
Answer: B
2. You are performing an HP-UX cold installation using the advanced option. Which parameters can you
set on the System Menu tab? (Select three.)
A. hostname
B. user passwords (non-root)
C. filesystems
D. additional interfaces
E. software filesets
F. time zone
Answer: ADF
